Sway bar issues
Old Jun 23, 2022 | 11:10 AM
dagwood57107's Avatar
dagwood57107
Sway bar issues
82 F100 going to be used to haul around a slide in popup camper. My mechanic had it up on a lift and was able to get my rear sway bar installed, but the front sway bar wouldn't clear steering/suspension and he couldnt install it. So do I leave the rear and run without front sway bar (does have steering damper) or remove the rear and go with none? He said it should be fine to run it this way, but I thought I'd get 2nd opinion
Old Jun 23, 2022 | 12:34 PM
Franklin2's Avatar
Franklin2
With the camper it should be fine. With the truck empty you can try it. Normal driving you won't notice anything, but if you do any slalom racing with it you may find the rearend wants to slide out more than it did before.
Experiment with it in an open area, make a long turn faster than you normally would and see how good the rearend sticks in the road after you install the bar.
Old Jun 23, 2022 | 01:29 PM
manicmechanic007's Avatar
manicmechanic007
Leave the rear one on there
Maybe look for a different style front one?
Remove the steering damper shock, install the sway bar and then re configure the steering stabilizer shock
Good luck
Old Jun 23, 2022 | 01:30 PM
manicmechanic007
The factory 4x4 one should work?
Old Jun 23, 2022 | 03:24 PM
Lariat 86's Avatar
Lariat 86
I don’t haul much in mine but, I do run a rear sway bar on my truck. To me there’s no big steering difference than before (normal driving) but, it rides much better because it removed a lot of body roll when cornering.
Old Jun 23, 2022 | 03:47 PM
dagwood57107
Good luck
I wasnt able to find a 2wd front sway bar other this Hellwig I got off FB marketplace, which was still in the box manufactured 2012. It was supposed to be the right one, but maybe since I have an F100 with the small brakes something else is different under there?? I have no idea. SDTruckSprings didnt have anything and no other place had any either. Thanks everyone for the input!
Old Jun 25, 2022 | 06:18 AM
FuzzFace2's Avatar
FuzzFace2
My 81 F100 has a lot of body roll with normal driving and 1 day i will look into sway bars for it
What were the part numbers of the 2 bars and who made them?
Small or big brakes up front should not make a difference on the bar fitting or not.
I would like to know what it was that that bar did not fit?
They say the 4x4 front bars fit, I have not tried.
On the rear bars know the early trucks used Ford 9" and around 83 or 84 they started using the Ford 8.8 rear and from what I remember reading the bars mount different but cant remember if the 8.8 will fit the 9" or not at this time?
As others have said leave the rear bar on and give it a try as it has to help on body roll over not having anything.
Dave ----
Old Jun 25, 2022 | 03:40 PM
dagwood57107
Dave ----
I have left it, and tested it a little. It makes a difference, not huge and have not tested it with weight in the rear yet. I also have helper springs in the rear and its pretty stiff. Rides perfect with weight back before the sway bar. Anyways, the front bars were Hellwig 7489 1 1/8" bars. At least thats what I "bought" and thats what the box says. I have no way to tell if that is the actual part that was sent or not. They quit making them in 2012 I believe and I got them off fb marketplace. They were supposed to fit so I dunno.
The rears were Adco 341 1" bars. They worked without any issue and I bought them new from sdtrucksprings.com for $241.82 with shipping and tax. Pretty sure I have a 9" rear end w 3.25 gears. My F100 was almost undriveable when I first got it going. Shocks helped more than a normal person could imagine and steering damper helps quite a bit with RR tracks and bumps in the road. Night and day difference between now and then.
Old Jun 25, 2022 | 04:26 PM
FuzzFace2's Avatar
FuzzFace2
Thanks for the numbers.
The suspension has been rebuilt, poly in front rubber out back, with new KYB shocks all around and a new Blue Top steering box when I did a full 4 year cab off frame rebuild.
It rides pretty good for a unloaded short bed pick up but I can feel it lay over in turns and would like ot fix that same day (only been on the road over 2 years now) LOL
Dave ----
Old Jun 25, 2022 | 05:45 PM
dagwood57107
Dave ----
My truck leans pretty good in corners too. I'm not sure if I can get front adco sway bars or not. I know Hellwig quit making them. I wish I could have done a frame off restoration, but all I have is a dirt driveway and very minimal tools. Plus I'm old and disabled. Crawling in the dirt isnt fun anymore lol
kramttocs
Sep 6, 2016 12:54 PM
79Supercab
Feb 11, 2015 04:14 PM
1972RedNeck
16
May 12, 2012 01:25 PM
timf150
May 1, 2012 11:13 AM
weldman
Jan 25, 2002 01:49 PM
