Brake Rotor Removal
Old Nov 9, 2003 | 07:43 PM
Chaz23's Avatar
Chaz23
Brake Rotor Removal
I am pulling the front rotors off of my 89 F-150 4x4 and I can't seem to get them all of the way off. I pulled the manual locker out, but it still won't come off. I don't see a wheel bearing nut to remove, but just a weird hex shaped ring recessed into the hub where the axle end is still protruding through. What is my next step? Any help would be totally appreciated.
Chaz
Old Nov 9, 2003 | 09:27 PM
mikeindmills's Avatar
mikeindmills
use the search feature. i think this has come up a few times. but to get you started, there is a socket they make to get that nut off. then i belive there is a snap ring behind that. for more info use the search button.
Old Nov 11, 2003 | 11:48 AM
Gutter's Avatar
Gutter
your in for a treat after taken the exterior off youll see all the springs plastic junk don't mix them up, there is a c-clip inside the hub wall holding back a spacer as well as a ruibber o ring, may be disinagrated locking nut and spacer than a hub nut very large. that c-clip is well hidden covered by grease, small sharp knife and a pair of pliers to help.
Old Nov 11, 2003 | 01:30 PM
jbalestri's Avatar
jbalestri
There is also a castle nut that you'll need to remove. You'll need to get a "spanner socket" for a Dana 44 front end. Most auto stores have that one or have one you can borrow. You'll also want an impact of some sort(either electric or pnuematic). Once you get the outer castle nut off, there is a special washer that holds the next castle nut on. You might need some dental pics or something like that to remove it. It is often covered with grease, etc. Then, remove the next castle nut and the hub/rotor assembly should come off.
For pics etc, click HERE.
Old Nov 11, 2003 | 07:10 PM
Chaz23's Avatar
Chaz23
Got it off. Thanks for all of the usefull information. It really helped out. Thanks again.
Chaz
CPL. Chaz
Aug 27, 2013 01:46 PM
CPL. Chaz
Dec 19, 2012 04:53 PM
chaz3
Jun 25, 2007 10:45 AM
hoof
Dec 31, 2006 12:46 AM
chaz123
16
Jun 21, 2005 03:44 AM
