Battery Powered Impact Wrench
Old Jun 22, 2022 | 12:53 PM
  #46
SuperDuty Wannabe's Avatar
SuperDuty Wannabe
Another vote for the Milwaukee M18 Impact. It makes easy work when I rotate the Tires on my F450.
Old Jun 22, 2022 | 12:58 PM
  #47
duckduke's Avatar
duckduke
I keep this under the back seat Kobalt 0.5-in 450 ftlbs Air Impact Wrench in the Air Impact Wrenches department at Lowes.com
Since I already have an air system and air hose on board ........... I keep this Kobalt "Compact" Impact and this
8 lug impact set: 8 lug impact set:
I leave my battery systems at home most of the time but prefer the Kobalt tools.
The newest and best one for lugs is this one rated at 750ftlbs
I have the predecessor at 650 ftlbs
I also have a smaller more compact one rated at 150 ftlbs
The reason I prefer these Kobalt tools is every Kobalt tool I've owned has been very good quality.........and also when I started collecting the battery tools the Kobalt batteries were about 1/2 the price as many of the others.
I have used many brands of battery tools and the Kobalt batteries seem to be as good as any. I use some of the tools regularly and still have all 6 batteries I've bought.......... never had to replace a battery, so far anyway.
Old Jun 22, 2022 | 01:43 PM
  #48
Keokie's Avatar
Keokie
Originally Posted by CheeseheadFord
My post wasn't directed at anyone with maintenance or lack there of, just pointing out my opinion as is everyone else. However since you brought it up if I was a betting that at least half of blow outs are due to that whether anyone would really admit that or not.
4 times in 43 years is once every 10 years, that's pretty infrequent IMO, using something 1 time in less than 10 year avg isn't something I personally need, but knock yourself out if you believe its a need for you.
Comparing an impact to fire extinguisher is foolish. One saves you a few minutes taking a tire off, one can save your vehicle or life from a fire, cmon man.
If you are dealing with high-torque 8 or 10 lug wheels, that impact will save you more than a few minutes. And every minute working on the shoulder of a high traffic interstate increases the considerable risk to your life.
Tire maintenance is very important, but if you tow a lot, you will get flats.
Old Jun 22, 2022 | 02:08 PM
  #49
camarochevy1970's Avatar
camarochevy1970
Yep, my trailer tires get flats more often then I like, but now every time I take a trailer I take the M18 impact, can have the spare on in 5 minutes and be off the shoulder
Old Jun 22, 2022 | 02:20 PM
  #50
morehouse7's Avatar
morehouse7
Originally Posted by gillie2019
What's a good deal on an impact wrench for RV and Truck? I'm getting too old to jump on the tire iron to loosen the bolts.
Thanks,
Gillie
And back to the original question....
Best deal is a Harbor Freight 1/2" drive model of your choice unless you have a current cordless system battery and you can buy just the tool.
Old Jun 22, 2022 | 02:28 PM
  #51
CheeseheadFord's Avatar
CheeseheadFord
I guess I should be thankful I live in the rural US and rarely have to travel on interstates to go where we camp. Retirement goal would be be to be full timers and then at that point maybe I would agree with your assessment .
Old Jun 22, 2022 | 03:58 PM
  #52
Poncho450's Avatar
Poncho450
Is it that foolish of a comparison? As stated earlier and believed by some others, every second you're at the side of the road on a crazy interstate changing a tire is a danger. If I can get that done in 5 minutes or less with a power tool as opposed to using a breaker bar with possibly a cheater bar added to the mix you can bet that's what I'm going to do. Every second or minute saved does indeed increase my chances of getting away safely. The price of an impact is a pittance for that.
As far as comments by others about tire maintenance, there's only so much you can do. Start the trip with correct pressure and don't have them overloaded. It's a fact of life that many trailer makers send them out with very low budget, questionable quality tires. And many of those tires are in fact China made.
On long trips I jack the trailer up and make sure that there's no shuck in the wheels. If so, the dust caps come off and things are tightened and inspected to make sure the bearings are intact and greased. Some tires simply aren't going to live as long as I'd like with high temperatures and sustained interstate highway speeds no matter how many precautions are taken pre trip.
Old Jun 22, 2022 | 06:08 PM
  #53
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Am I the only one who would drive on the flat to the nearest exit? Exits are usually every couple miles (on the east coast anyways), so I'll gladly sacrifice the tire if it keeps me from dying on the interstate.
The last camping trip we took in my buddies new-to-him RV, we lost 2 tires. First one, we were able to hit an exit and change it on a secondary road. Second blowout was right under an overpass just after the exit, so we pulled off on the other side of the on-ramp so we at least had one lane between us and traffic.
Old Jun 22, 2022 | 06:13 PM
  #54
Keokie's Avatar
Keokie
Out west, it is common to be 8, 10, 20 or more miles from an exit.
Old Jun 22, 2022 | 06:37 PM
  #55
HRTKD's Avatar
HRTKD
I drive a lot of two-lane roads in CO, WY and MT. There are no exits. Pulling over would put me in the ditch. If it was a trailer tire, I would limp along until I found a wide spot. A flat tire on the truck though would be a tough call.
Old Jun 23, 2022 | 06:10 AM
  #56
IADiver's Avatar
IADiver
My vote is Milwaukee M18, but that is what all of my other job tools are. If I were going to buy a standalone, I would look hard at Rigid. They are Home Depot exclusive now but make some pretty good stuff. The big thing is look at torque and battery size. Impacts REALLY eat through batteries.
Old Jun 23, 2022 | 06:17 AM
  #57
last5oh_302's Avatar
last5oh_302
I've used my new RIDGID (Home Depot) impact a few times now and what a treat after years of using breaker bars and ratchets. I decided to go with RIDGID because they have a lifetime battery warranty, and they perform as good as more expensive brands. I picked up a few other tools from them as well. I just wish RIDGID made a chain saw, and since they don't, I had to buy another brand.
Old Jun 23, 2022 | 07:11 AM
  #58
Poncho450's Avatar
Poncho450
If you've got a dual axle and/or can limp it along, not a bad idea.
Old Jun 23, 2022 | 07:36 AM
  #59
CheeseheadFord
I was going to add it to my response but figured I was flamed for saying an impact was not a necessity that would just receive the same reaction, so I'm in agreement with you as well.
Old Jun 23, 2022 | 12:19 PM
  #60
William Owens's Avatar
William Owens
I've been looking at the Rigid 1/2' impact, I like my Ridgid Drills and small impact. One of my drills is 15+ years old, and they've replaced the batteries and charger a few years ago not problem. I'm wishing they made a blower.
