Torque specs.
Old Jun 19, 2022 | 07:26 AM
nxtdiesel's Avatar
nxtdiesel
Torque specs.
This is for a 2017 F350 SRW 4wd 6.7.
Could someone with a service manual tell me the torque specs for the front and real brake caliper pins and mounting brackets and also for the 4 nuts that bolt the front hub assemblies to the steering knuckle? (At least that’s what I call it).
I was waiting for Haynes to release a service manual, but it doesn’t look like that is going to happen so I guess I will have to order a factory one. But in the meantime if someone could help me with this, I would greatly appreciate it! Thanks!
Old Jun 19, 2022 | 12:23 PM
MrOneEyedBoh's Avatar
MrOneEyedBoh
55ft # on the caliper bolts
203ft # on the caliper bracket bolts.
At least that is what it is for my 19 f250 SRW 4WD 6.7
Old Jun 19, 2022 | 02:59 PM
nxtdiesel's Avatar
nxtdiesel
Thank you, I actually found that for the front. Does anyone know the specs for the rear? And for the hub assemblies?
Old Jun 21, 2022 | 06:15 AM
lemforder's Avatar
lemforder
Some of the torques you're looking for should be in the attached.
Old Jun 21, 2022 | 10:54 PM
nxtdiesel's Avatar
nxtdiesel
Great, thank you very much!
Highboy74
Apr 29, 2021 12:25 PM
deezel
Apr 14, 2007 03:25 PM
Jeff396
Jan 23, 2007 05:23 AM
