No crank
Old Jun 18, 2022 | 03:50 PM
Aymara Alvarez's Avatar
Aymara Alvarez
1st Gear
No crank
Good afternoon, I have a f350 2005 6.0. Right now I'm having a problem with it. I always do the mechanics because I have a lot of knowledge. Besides, the forums have helped me a lot, as have the experts who have videos on YouTube. The thing is that I just changed the pug plugs and the injector harness. I've already been changing the injectors. I'm missing 4 of 8. What happens is that after I changed the harness and the pug plugs, I put the scanner on it and it's saying that all the injectors are bad, even the 4 that I changed two weeks ago and it doesn't want to start, the oil is coming and the diesel is also coming in fine, please someone help me point somewhere. I have always seen that here they help people, thank you and blessings for this page, it has helped me a lot
Old Jun 18, 2022 | 05:05 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. You will get good responses, to your question(s, if you take them to the Super Duty/Heavy Duty forums. The experts there, will be glad to help you.
Don't forget to check out and join the Florida State Chapter too.
Old Jun 18, 2022 | 11:02 PM
Fomoko1's Avatar
Fomoko1
Moved to this forum.
Old Jun 19, 2022 | 07:29 AM
Brotherbillstruck's Avatar
Brotherbillstruck
Hello. Are you positive that the harness plugs at the F.I.C.M. are pushed all the way in and they "clicked" into their sockets (also look for bent pins)? Not sure if the first and second injector harness plugs can be reversed but I would check that also. Also, did the truck start after you replaced the 4 injectors two weeks ago? You are going to have to go over everything you touched up to when the truck was running last. Here is a picture of the FICM showing the plugs and their function.
https://mid-atlanticema.org/wp-conte...Tech-Guide.pdf
mastersativa
New Member Introductions
Apr 17, 2018 08:09 PM
Harwell
Sep 25, 2017 08:30 PM
Slingmud
Jan 1, 2015 08:47 PM
