Fuel pump?
Old Jun 24, 2022 | 11:46 PM
BigBlue2's Avatar
BigBlue2
Even though it worked for you before, the idea of it having to pull though a non-running pump doesn't seem right. I would pull the sending units out and put a piece of hard line in place of the old pump. Then re-install the sending units.
It probably depends on the type of pump. Seems most of the in tank pumps are rotary vane and I think that type of pump is probably more open than the filter sock if it's there.
Jpegg01
May 8, 2019 02:22 PM
