Sponsored by: Auxito
Lost chip
Old Jun 15, 2022 | 09:40 AM
Mama04's Avatar
Mama04
New Member
Lost chip
I lost my chip for my anti theft system. Is there a way to replace the chip? Or bypass the system? Or even take it out completely?
Old Jun 15, 2022 | 12:56 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Need more info. What year and model? Is the device a FORD product or an aftermarket unit. If aftermarket you will need to contact the manufacturer. What do you mean by "CHIP" ? A chip is normally an electronic device that is soldered on a curcuit board.
Old Jun 15, 2022 | 03:52 PM
WWR's Avatar
WWR
That looks like an aftermarket transponder system?
I had one on an '03 Suburban, it came that way from a PO. There was just a large yellow wire in the steering column wiring they had interrupted to install it. I removed any aftermarket wiring and spliced the factory wires back together-- DONE.
Obviously Ford wiring colors will be different
Old Jun 16, 2022 | 08:42 AM
manicmechanic007's Avatar
manicmechanic007
That is aftermarket
Simply remove it and re hook up the wires they cut to install it
The rest of the wires you can just pull the scotch locks they used
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
Jul 15, 2021 07:21 AM
carid
Jan 19, 2021 06:50 AM
carid
Nov 20, 2020 08:56 AM
carid
Feb 24, 2017 07:27 AM
5 Star Tuning
Sep 17, 2012 04:48 PM
