Engine
Old Jun 11, 2022 | 09:43 PM
fordfan76's Avatar
fordfan76
Trailering
Engine
Got the opportunity to buy an Explorer 5.0 from a 96 to go into my 72. It currently has a 302 out of a 74 Maverick. It’s junk…runs on 6.
I know I’ll need an electric fuel pump, but will my Edelbrock 4bbl intake that is on the 74 bolt to the 96? I know I have to change out the cam gear on the distributor as well… what else? I’m running a duraspark II now. No points.
Old Jun 11, 2022 | 11:38 PM
85e150's Avatar
85e150
Intake should bolt right up, you are already on the distributor gear....
@Conanski has the rundown on the SBF and might offer a tip or two if he passes by.
Good luck with it!
Old Jun 12, 2022 | 01:43 PM
gump1376's Avatar
gump1376
I believe the water pump is different on the two as well. If your explorer has the serpentine belt, it's a reverse rotation water pump from my recollection.
Old Jun 16, 2022 | 08:15 AM
fordfan76's Avatar
fordfan76
Trailering
Thanks for the replies! Looks like it’s doable! I had heard at one time that a 4bbl intake won’t fit on a fuel injected engine because of the heads.
Is there any reason why I couldn’t run the serpentine belt and accessories?
Old Jun 16, 2022 | 04:11 PM
1TonBasecamp's Avatar
1TonBasecamp
None at all, and in fact with the Explorer you might actually WANT to run it!
Not that our pickup trucks need as much help with clearance as the Early Broncos do, but the very compact drive system is so nice that there's really no reason not to utilize it if you have it.
New 4G alternator, decently efficient water pump (that can be serviced without removing all the other stuff by the way!), very nice small power steering pump, good A/C compressor and a fantastic clutch and fan setup that pulls a wicked amount of air, all run off of a single easy to find and service serpentine belt. Easy to keep a spare of handy as well...
The only reason I can think of that you would decide otherwise is if something in that drive assembly did not fit with things like inner fenders or lower crossmembers. They fit very well in a Bronco engine compartment (many of us have them now) but the passenger side drive bracket and lower idler pulley hang down pretty low.
You can source the smaller idler pulley if it's just a matter of fractions of an inch, but it all depends.
Is yours a 2-wheel or 4-wheel drive?
paul
Old Jun 16, 2022 | 04:13 PM
1TonBasecamp
Nevermind. i see it's a 4wd and that there looks to be a lot of clearance.
I forgot to mention one other aspect of change though. The distance from the fan to the radiator could change, but it sure looks like it would fit right into the area in your shroud.
Hard to tell from here at just a glance of course, but you can take some measurements and even create a bit of an extension if needed in order to keep the Explorer fan setup.
Paul
Old Jun 16, 2022 | 08:54 PM
351Cleveland C4's Avatar
351Cleveland C4
I'm in the process of putting a '96 explorer 5.0 into my '86 bronco. Using all explorer parts.
So I'm gonna keep an ear on this...
Old Jun 16, 2022 | 09:47 PM
1TonBasecamp
You should really like it. What transmission will you use?
my Bronco is a rocket, but a lot of that has to do with the gearing. The engine is bone stock right down to the EGR and exhaust manifolds.
But even though stock, the combination of the 4R70W, the 456 gears with Detroit Lockers and little barely 30 inch tires, it’s hard to keep them from spinning even on dry pavement. Hard to drive at all in the wet!
and even harder to keep the silly grin off my face!
yours should be much more manageable with the bulk of the big bronco on top of it versus my little bronco. But that might make it even more fun to drive.
Gotta love overdrive transmissions and low gears.
Old Jun 17, 2022 | 07:29 AM
351Cleveland C4
I'll still be using the AOD.
Yeah I've got 4.56 gears with 33s. Good combo.
Old Jun 18, 2022 | 09:23 PM
fordfan76's Avatar
fordfan76
Trailering
I plan to still run the C6, with 4.10 gears and around 35”tires. Should run ok I think! I doubt I’ll ever run over 60-70 mph, and no A/C..
rudigar25
Engine Swaps
Nov 25, 2009 07:58 AM
Bulldawg1081
Jun 21, 2007 12:40 PM
83 Capri 5.0
Alberta Chapter
Jan 24, 2004 07:16 PM
