Transmission swap
Old Jun 10, 2022 | 01:04 PM
Devin6868's Avatar
Devin6868
1st Gear
Transmission swap
Will a 1986 Ford f250 6.9 4 speed manual transmission into a 1990 Ford F250 7.3 that has a bad 4 speed automatic?
Old Jun 11, 2022 | 04:49 AM
tecgod13's Avatar
tecgod13
Yup
Pedal assembly may be different since the interior is a little different, I'm not sure on that one. But should be fairly straight forward.
Old Jun 11, 2022 | 11:34 AM
1986ed's Avatar
1986ed
As long as you have the bell housing from the 86 manual it will bolt right up onto your 90. The other thing you need to look out for is that you'll need to get a clutch kit and flywheel for a 86 and put it on your 90. They will bolt right onto the block just fine. But the clutch/flywheel that fits a 1990 will be too big for the input shaft off a 1986 4-speed.
I've done the opposite of what you're doing, I put a transmission from a 1990 onto my 1986. One thing that made my life 100x easier was using the cross member that came with the transmission I was putting in, not the one that came with the truck. In your case, that would be using the crossmember from the 1986 on your 1990. Drive shaft lengths is another thing to be wary of.
Old Jun 11, 2022 | 12:57 PM
Charmalu's Avatar
Charmalu
A clutch kit for a 90 would be for a ZF-5 pd which has a larger input shaft/splines.
Just order a clutch kit for a 86 F-250 4-spd trans.
I just ordered one from Parts Geeks, a Luk 12" part# 07-065.
$142.43 and final cost shipped $163.22
Charlie
dirty_diesel
May 13, 2013 07:27 PM
awhtx
Dec 10, 2010 10:23 AM
65fordy
Apr 26, 2007 09:17 PM
79bigblue
Dec 4, 2001 08:39 AM
