Suspension Thoughts?
There is probably nothing inherently wrong with the springs as they are being loaded exactly as intended but he definitely needs to scale it as there is several front spring options that he may want to entertain.
Really not needing to change to any special springs unless lifted or running offroad unloaded. 2 different circumstances.
OP, no 1st hand knowledge of your setup and you're driving, but I would definitely look at larger suspension products, my daily driver is a 550 that weighs in around 11k ( quadruple at when towing). I could not imagine driving at those speeds at that weight with regular shocks.
I drive plenty of regular f-150s, I own two F-150 raptors. The suspension on the raptors incredible, primarily due fox shocks, if I was trying to reproduce what you are doing, the first thing I would do is shocks.
And yes I have ran deavers on a Ram 2500 cummins so I am familiar with these products.
He can get by with shocks and tires. Address springs later if needed.
Need the scale numbers before deciding on front spring changes, often the front axle loses weight when these large campers are loaded into the back. The over hang really pulls the COG towards the back. Definitely want upgraded shocks...2.5s would be fun, but the cost is gonna sting. Anything with reservoirs would be an improvement. I'll second the idea of a front hitch and ebikes out front. Torklift makes a front hitch rated for 1000 lbs tongue weight.
It looks like many comments recommend Fox or Icon 2.5's, so I'll probably go that route in the front. These appear to come with and without oversprings. Since most of my weight is on the back wheels, I'm not sure oversprings are necessary on the front, but I'll ask for opinions on that. I've read that both Icon and Fox make good products, and that Fox provides a better street ride, while Icon provides a better off-road ride. I'm on pavement 95% of the time (freeway, getting to and from backroads), but when I'm off pavement, I may be off for miles - so I'd probably be happy with either of them. If anyone has any strong opinions on this, please share.
For the rear, I'm still thinking of replacing my Airlift 5000 Ultimates with either the Airlift 7500 or the Firestone 7500. My current system has 2 independent air lines run to in front of my wheel wells (I cannot run the lines to my bumper because the camper completely covers the bumper). From what I can tell, the Firestone bags are rated up to 150 psi, and the Airlift to 100 psi, so if I went with onboard air with dual controls, I'd choose Airlift's system that is wireless, or the Firestone system that requires running air lines. Thanks for the input that I don't have to have the air lines in the cab with me - but honestly, I'd like to have the ability to control from the cab. For example, if I'm leaving a gas station and there is a dip in the road leaving the station (as is often the case in Utah where they use dips to channel water away from the street), I'd like the ability to air up a little to raise the rear and prevent dragging the bike rack, and then air down again after getting on the road - without needing to exit the truck to make the air changes. Do the Airlift and Firestone bags both provide the same amount of lift? Raising the bags by an inch would probably raise the bike rack by 2 inches, which is often enough to help.
Should I look at Fox or Icon shocks for the rear as well, and if so, would oversprings be more appropriate for that? Sorry if these are novice questions - I've never messed with suspension before, other than when I put on the Airlift bags on.
Thanks also for the suggestion to move the bikes to the front of the truck. I should have mentioned, however, that I already tried that. It helped the weight distribution, but messed up my adaptive cruise control - which is a godsend on the freeway, so I went back to putting the bikes on the back. I think the adaptive cruise uses the front camera, and the bikes confuse it - if there was a way around that, I'd really like to hear about it! I know I could just use the normal cruise control, but I'm hoping not to go down that road if I can find alternatives.
Steve
You're absolutely right about the camper moving the COG toward the rear. The last time I weighed in I was 4,700 on the front axel and 9,700 on the rear. This was without the supertruss, bike rack and bikes, and some gear I've added since then, so I'm going to be at least 250 lbs more in the back, and probably a bit less on the front. I'm not sure I need more spring in the front - but definitely need more shocks, and the 2.5's seem to be what most people recommend. Does this apply to the rear as well?
I should have mentioned - I already added a front receiver and tried the bikes on the front. Helped the weight distribution, but killed using the adaptive cruise control (I don't know if the bikes mess with the camera or the radar sensor, but regardless, the truck behaves erratically because it thinks something is ahead of me). I could just use the normal cruise control, and maybe that is what I should do, but the adaptive feature is pretty important to me, and I'm trying to find other solutions before going back to bikes on the front...
Thanks for the reply.
Steve
certainly on the high end of what your current bags will do, an upgrade there won't hurt. Having in cab control would be handy for all the reasons you described. Not sure between fox and icons, my gut is fox but it would be curious to see if either cab sell you something with custom valving with the camper in mind.
Seems like your on the right track, hope things work out.
Honestly, I don't think front springs are an issue - with all the weight in the rear, I'm probably lowering the weight on the front (the CG of the camper and bike rack combination is probably behind the rear wheel). I know I need different shocks, but front springs are probably fine. Looking for thoughts on rear shocks too - am I looking for the same idea there?
The last I scaled it, I was 4,700 in the front, and 9,700 in the back - but when I weighed in, I was without the supertruss, bike rack and bikes (so add 250 lbs to the rear). I don't think my Airlift 5000 bags are big enough for what I'm doing - which sucks, because they weren't cheap, but if I need to upgrade them I will. Still working on those ideas too. The last trip (Death Valley, Canyonlands, and other places between home (in WA) and the southwest, made me think I need to beef things up.
Steve
Truck has mods that set me back a pretty penny but are worth it for my usage.
Truck came with some Fox 2.0's all around and they work great unloaded and loaded
Replaced the existing rear springs and got a custom made progressive set that are made to carry the actual weight of the camper loaded up. When camper is on my overload springs don't even make contact. Had a spring shop do the work and it cost me about 2k. Had the camper loaded up on the truck when they made the set up and installed.
I purchased and installed the same airlift 5k bags you reference but I also got the onboard compressor and mounted it up under the truck and it has a remote digital keypad for inflated and deflating and I can visually see how much air is in each side.. Bags are separately connected to compressor so they can operate independently, Even mounted a fill valve at the rear bumper sides in case the compressor rolls a six and I can inflate with a tank or air hose if needed. I run them at 5psi when not loaded and then put 50psi in to stiffen and sway I get. Inflating the bags don't raise the back end at all they just provide additional resistance.
Purchased and installed big rig sway bars front and rear as they really help.
Removed the factory steering stabilizer and installed a Fox 2.0 dual set-up in front and it made a noticeable difference. Don't even spill my drink when off-road.
But the very first thing I did was install some Toyo M/T tires and Method NV305HD's rims.
Have had this set-up for 2 years and have been to the local mountains and desert's as well as the upper half of Baja without any issues.
Last year we took a month long trip up through Moab UT and up into Idaho and Wyoming and was off-road alot of the time looking for places to boondock.
This year we went back to NC for 6 weeks and were off the beaten path going and coming home ( san diego) nothing broke or failed.
Invest in the springs and let them do their job would be my advice for a starting point and then add as you see fit.
Sunset outside moab:
Heading over to the Moki Dugway trail.
Couple of pics local.
