Check my brake work?
Old Jun 8, 2022 | 05:53 AM
78Custom302's Avatar
78Custom302
Is the blue spring installed correctly? Does everything else look correct?
Old Jun 8, 2022 | 07:15 AM
DB429SCJ's Avatar
DB429SCJ
Adjuster spring (blue) is backwards. some good pics;
Old Jun 8, 2022 | 07:52 AM
DB429SCJ's Avatar
DB429SCJ
It also appears that the shoes are reversed. The primary shoe-the one with the shorter lining, always goes toward the front of the vehicle. In the video, it looks like he has both primary shoes on the same side.
Old Jun 8, 2022 | 09:09 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on look at all 4 shoes and make sure you have 2 and 2 and not 2 that match on the same side. Pic is R/H rear out of my saved folder. Yes your blue lower spring is on backwards. Short end hooks in the shoe, long piece to the brake adjuster bracket.
Old Jun 8, 2022 | 11:09 AM
tbear853's Avatar
tbear853
Yeah, as others said, blue spring needs a flip to get it's coils away from adjustment lever ... and with drums, short shoe always to front. In operation, the front most shoe is pushed out against the rotating drum surface and this tries to turn it downward where it pushes against the adjuster and the adjuster is pushed against the rear most, longer shoe up against the anchor pin where the "buck stops" The longer rear shoe is forced into a wedging action against that pin and with the other shoe pushing it, it wears faster against the drum, so it always gets the longer lining since it gets wedged tighter. Drum brakes have a property of "self energising" as a result. Usually the steel part of the two shoes is the same, they just line the one shoe with longer, one with shorter ... linings
Old Jun 9, 2022 | 10:36 PM
nutter3's Avatar
nutter3
BOB--Big on back. I just read that somewhere (here maybe). Anyway, it's an easy to remember acronym.
Old Jun 11, 2022 | 12:24 PM
78Custom302
Yeah, I went back to my Haynes manual and see that I missed what they meant by primary shoe.....:-/
Old Jun 11, 2022 | 12:25 PM
78Custom302
Great pic! Thanks so much!!
Old Jun 11, 2022 | 02:16 PM
78Custom302
I am noticing that the blue spring fits into the shoe kind of weird. The hook is an odd shape to fit in that hole in the shoe. Am I supposed to reshape the hook? I think that's why I flipped it around originally--it seemed to fit better that way....
Old Jun 11, 2022 | 04:02 PM
78Custom302
Got it!
I think this is right now....
Old Jun 13, 2022 | 07:23 PM
78Custom302
How does this look?
Old Jun 13, 2022 | 07:43 PM
78Custom302
Here is the way it should be....what do you think?
Old Jun 13, 2022 | 07:46 PM
78Custom302
The left side adjuster comes down a little too far which doesn't stop the star wheel from turning the opposite direction. Has anyone heard of the adjuster cable being too long?
Old Jun 13, 2022 | 10:53 PM
tbear853's Avatar
tbear853
The cable pulls up when the brakes apply in reversing direction, whether you back it up or just let it roll before stomping on the brake, then when you let up on the brake it's then the blue spring pulls the arm down to move the star wheel a tooth. You adjust the brakes manually, I do, so there is a light rubbing sound as the drum turns ... then after that the self adjusters just at most adjust in little 1 tooth adjustments during everyday driving. The self adjusters are not intended to adjust initial set up. That rear shoe will be pulled away from the anchor, the cable stays, and that action pull upward on the arm. Once there is no excess room for mor adjustment, then there is not enough movement to pull up on the arm, so adjustment stops until wear allows enough room to work again. It's self adjusting and self stopping.
Looks fine to me.
ultraranger
87
Dec 25, 2016 05:24 PM
Grubbworm
Projects
225
Sep 11, 2016 07:40 PM
dmccorkle911
Missouri Chapter
May 11, 2016 01:59 PM
theodore/teddy
May 9, 2016 07:14 PM
clhart426
Mar 7, 2012 06:31 AM
