oil pressure
Had to work this morning at 5:00am........when I started my bronco the oil pressure didn't move......and my engine light stayed on..........I figured it was just because it was freezing outside..........so i left it till the truck warm up a bit and it finally moved, but it only got to the "N" on the normal. I drove for a good 10 minutes and it didn't move much farther...........Its stayed at the same spot on the drive home....when it was much warmer. Could it be a oil pump problem or as simple as changing the oil ( I might be a little over due!) Any help would be greatly appriciated
LTRBUC "Let Her Buck"
