Sponsored by: Real Truck
2002 f350 7.3 Stalling
Old Jun 4, 2022 | 12:17 PM
Pvereb421's Avatar
Pvereb421
3rd Gear
Hey guys I own a 2002 F-350 7.3 auto with 108,000 miles on it. Bought it off a old man who used it to go to lake to fish so after 19 years phrior to becoming my old reliable I decided to replace the glow plugs, injectors (swamps 175) turbo back exhaust and CAI. (yes I know I didn’t need to do those things but I’m planning on running this thing for as long as I can
Recently parked the truck for a few weeks due to bidennomics supporting $6.25 gal diesel. I started the truck up a couple times during that time no issues. Yesterday and today I started the truck and noticed check engine light was on looked to my edge CT3 monitor and said no codes present. I cleared the code and was using the truck and it stalled several times when slowing to stop at red lights and stalled in neutral going through car wash. I’m gonna change fuel filter see if that resolves the issue but hoping to see what you guys have experienced. Thanks
pvereb24
Old Jun 4, 2022 | 01:58 PM
Tunafish389's Avatar
Tunafish389
I would start with the CAI. The put the factory back on, it was already CAI with plenty of breathing...
Old Jun 4, 2022 | 06:31 PM
Pvereb421's Avatar
Pvereb421
3rd Gear
I wish I could the original owner put the k&n on it I don’t have the factory set up
Old Jun 4, 2022 | 08:58 PM
Evan_P's Avatar
Evan_P
When it stalls is it like the key was shut off or does it slowly die out?
Old Jun 4, 2022 | 10:07 PM
Pvereb421's Avatar
Pvereb421
3rd Gear
Turns off like if I killed the motor but shift to neutral and fired right back up no issue….. if I’m slowing down to light seems like the rpm’s might be slightly higher and then will drop down and start to sputter then turn off
Old Jun 5, 2022 | 10:38 AM
Old and soft's Avatar
Old and soft
Start by checking the engine harness where it usually rubs on the drivers side valve cover. Check the tin nut on your icp while there. Then get forscan and chart some pid's. Ipr, icp, cps, ect. Then get this thread moved to the 7.3 forum for some sound advice, not some wag about your cai.
1984oldn’slow
Apr 24, 2022 10:14 PM
lucco32
Sep 22, 2012 07:36 AM
LoyBaird
Aug 1, 2012 07:25 PM
bigdog194
18
Dec 8, 2010 12:12 AM
Fomoko1
18
Jul 8, 2008 09:45 PM
