Hey all, I have a 94 450 with the idi 7.3, and both of my exhaust manifolds are cracked and need replaced....I figure now is the time to consider putting a turbo on the truck. Before I pull the trigger on parts, I have (what I figure) 2 options:
1- buy stock replacement manifolds and an aftermarket turbo kit
Or
2- find a donor powerstroke and convert over (is that even possible?)
You also might consider having the manifolds repaired. A good welding shop should be able to repair cast iron. Of course, adding a turbo is always a good MAW project.
Ironically enough, I'm the machinist at a weld shop, but for the price of replacement, repair isn't worth the time....go figure
