Sponsored by: Real Truck
Locking rear differential
Old Jun 2, 2022 | 06:26 PM
Goolz's Avatar
Goolz
1st Gear
Hello all,
looking for info on removing a locking diff from a 3E rear and putting it in a 31 rear. Ever been done? Thoughts? Thanks in advance.
Old Jun 3, 2022 | 07:54 AM
bajaphile's Avatar
bajaphile
I'm assuming the 31 correlates to a 3.73 LSD axle (SRW, Sterling 10.5). I am not sure what the 3E is, but I'm assuming it is the newer 10.5 sterling (2011+).
I am currently running a Ford E-locker from a newer 2011+ Super duty 10.5 in my 2001 rear. The only "mod" is to remove a tang off the speedometer tone ring before bolting it onto the carrier.
Old Jun 4, 2022 | 12:15 AM
RigCity's Avatar
RigCity
Might as well swap the full axle
Old Jun 4, 2022 | 12:42 PM
reptar0077's Avatar
reptar0077
Actually a really good point, I'd look at junk yards for costs on a full axle buy. Then if I could find one, I'd pop it open to inspect that gears are still good, & replace with good synthetic fluid.
Old Jun 5, 2022 | 12:30 PM
PROSTOCK's Avatar
PROSTOCK
It's what I did to change from 3.73's to 4.30's; $400, didn't have calipers, so used my old ones. Make sure the drive flanges are the same, or get the drive shaft end that matches. I also replaced the crappy brake backing plates.
Old Jun 5, 2022 | 08:15 PM
99.5_Superduty's Avatar
99.5_Superduty
Be aware of a few things if you are considering an axle with a factory e locker (2011+ axle).
1. Rear axles from 2005+ are a different width than the ones used in the pre 2005.
2. 2005+ axles use metric lug nuts whereas pre 2005 use SAE
3. 2011+ axles do not have a VSS in the pumpkin. You will need to add a tone ring to the ring gear and then drill two holes in the pumpkin. One for the VSS and another threaded hole for the retaining bolt.
Old Jun 6, 2022 | 05:57 PM
RigCity's Avatar
RigCity
Heres the thread how to do it once you price out paying someone to set the backlash etc it make it with it to do the full swap w a 10 year old newer assembly even more so. Also I just bought a new tone ring to make my life easier however I'm sure you can remove the old one. The axle is about 1-2 inches wider my truck has been successfully aligned. As you can see I went to machine shop just because I didn't want to deal with drilling the hole and tapping it. Depending on your experience maybe that's easy for me it would have been the most challenging part of the job. I can confirm this is major update as my 4x4 was not working at the time and use of the e locker saved me in off road situations until able to install a new front driveshaft.
https://www.ford-trucks.com/forums/1...f250-help.html
Old Jun 6, 2022 | 06:02 PM
RigCity's Avatar
RigCity
Also if your truck is lifted MAYBE the PMF suspension top u bolt plates will let you shift the axle back enough while retaining the factory driveshaft.
https://www.pmfsuspension.com/Adjustable-Alignment-Pin-Ubolt-Top-Plates_p_33.html I am confident that would work however needs firm measurements taken. This also centers your wheels in the well if lifted. If you could use that it would make the update even more worth it for you/your gonna have to swap u bolts anyways as they are single use.
Old Jun 7, 2022 | 05:23 PM
speedfreak78's Avatar
speedfreak78
I'd swap the whole axle, used gears can be tricky. I was taught to pattern used gears before you pulled them and then try to match is as closely as possible when you swap them. If it's too far out from how it was, it can cause issues like gear whine, vibrations, accelerated wear and added backlash as they wear into the new setup.
Old Jun 13, 2022 | 08:07 PM
00t444e's Avatar
00t444e
99-04 Trucks do use metric studs, 14mm to be exact.
Old Jun 13, 2022 | 08:35 PM
99.5_Superduty
My apologies you are correct. I misspoke when I said SAE. They are different lug nuts. The pre 04 trucks I think use 14x2.0 and the later ones use 14x1.5. Or it might be the other way. Either way, they are different.
Old Jun 13, 2022 | 08:39 PM
99.5_Superduty
The VSS was by far the most intimidating and challenging part of this swap for me. I ended up doing it with a buddy of mine. I could have done it myself, but somehow drilling into the housing was pretty scary and he had no issues drilling into it. The thread above provided excellent guidance. Thanks again @RigCity
Old Jun 14, 2022 | 09:04 AM
bajaphile's Avatar
bajaphile
In the end it might be easier simply swapping the carrier... In my situation I was doing a re-gear anyway, so it was an obvious choice.
