Hesitation
Old Jun 1, 2022 | 11:50 AM
CGRetired's Avatar
CGRetired
4th Gear
Hesitation
Recently had to put a windshield washer pump in that required removing the right side battery on my 2005 F250 6.0 diesel. Upon completion of that job and every thing hokked up i had a slight hesitation. Then everything was fine. I don't use the truck much. A week later after a trip to town when stopping at a traffic light the truck did nothing with pressing on the pedal. It was still running but nothing making the engine go. I held the pedal down all the way and it eventually started working.
Did something need to be reset or checked after disconnecting that battery?
Old Jun 1, 2022 | 01:47 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE.
Just basics I guess, but make sure you didn't accidentally disconnect something?
Old Jun 1, 2022 | 01:53 PM
CGRetired's Avatar
CGRetired
4th Gear
I went back and tightened the two batter connections and the two leads to the positive side. Guess Ill have to do a test drive to see if it happens again.
Old Jun 1, 2022 | 05:24 PM
redford's Avatar
redford
If you want, I can move your post from the truck forum to the 6.0L Power Stroke engine forum. You might get better advice there.
Old Jun 2, 2022 | 08:55 AM
CGRetired's Avatar
CGRetired
4th Gear
Thanks. That's probably a better place to start with.
Old Jun 2, 2022 | 09:11 AM
redford's Avatar
redford
Moved to 6.0L PSD engine forum. Good luck with your repairs
RBerry9511
May 1, 2022 09:40 PM
lakewood
Jan 20, 2016 01:01 AM
danray35e
Nov 7, 2012 04:27 PM
CFDLT
1947 and Older Ford Trucks
Aug 13, 2010 09:53 PM
redsharkcvn73
Jul 22, 2009 06:28 PM
