Montana Chapter Join Chapter , Leader: Sailor_Roy
COASTING INTO JUNE
Old Jun 15, 2022 | 09:25 AM
  #106
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Good morning to all the Rowdy Cowboys and Patriots.....
Wednesday morning has arrived with high winds and light rain here & there. 50°F ...... high of 70°F expected, assuming we don't get blown away with winds of 25 - 35 mph right now.
HD scheduled is 1530 - 2100 today.....
Not sure if I am going to make it outside today....... yuck for weather.
Old Jun 16, 2022 | 12:37 AM
  #107
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Good shift at HD today........
Yummy Beef Stew for dinner.
Weather should be great tomorrow (Thur)....... I expect to get a bunch accomplished on the TT. No HD....
Past my bedtime.......
Old Jun 16, 2022 | 08:02 AM
  #108
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Morning Sailor ! Hope you get the weather to be able to get done with the TT. Enjoy the day off from the green store.
Old Jun 16, 2022 | 08:40 AM
  #109
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Good morning to all the famous Cowboys and Patriots......
A new day has arrived without 40 mph winds......
48°F and headed to a hot 84°F..... I expect the humidity will be a little high....
No Orange Store Bud.......
TT work day, I do expect to get a bunch accomplished......
Enjoy this great day that we have been given.....
Old Jun 16, 2022 | 01:07 PM
  #110
GLR's Avatar
GLR
Hope that you can "get'er done" , Roy.
Old Jun 17, 2022 | 07:19 AM
  #111
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Morning Sailor ! Guess you worked tight thru computer time. Hope you got a lot done . We're be gone from this afternoon to Sun PM getting #1 Grandson married off ! #2 beat him by 3 years .
Old Jun 17, 2022 | 08:37 AM
  #112
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Howdy Cowboys and Patriots......
A new day has arrived..... Feet hit the deck about 0630.
Light breeze and sunny skies..... Humidity is a wee bit high, but that should lessen as the temps increase. 48°F & 84% humidity. Forecast is for 91°F today.....
This will be the first day that we hit 90°F or higher..... I do believe the A/C will get it's first run for the year.
POD calls for:
TT work to continue.
HD 1520 - 2100
Yesterday I did make some good progress on the TT project
Old Jun 18, 2022 | 08:26 AM
  #113
5_labsownus's Avatar
5_labsownus
Sensational Saturday morning Montana, Roy, Bug, Tim and all the TT rebuilders and Cowboy crew.
Looks like you made some good progress and it is coming back to gether!
It has been an interesting week with the Temperatures in the high 90's and index of 110-111° coupled with 2 sever storms dropping 1.1 inched in several hours and another dropping 0.81 in 30 minutes. On top of that we lost power for 28 hours through the sever heat. Then again 3 hours yesterday while they made permanent repairs to the down lines and broken poles. It was a large sycamore that fell, plocked the road for 4 hours and took the lines out by breaking 2 power poles off!
Well today is more seasonable in the 70's, low RH, nice breeze and warn full sun! Off to the Range for the annual picknick and social event.
Old Jun 18, 2022 | 10:13 AM
  #114
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Howdy and Good morning to all the Fine Visitors, Cowboys, Rustlers, Sailors and Patriots.....
Feet hit the deck this morning at 0700.... Butt hit the recliner 15 mins after that with cowboy coffee in hand..... eyes closed 7 mins later.....
The clock just hit 0900..... I am awake Fresh coffee .... yummy !
Some clouds and clear sky...... light breeze of 10 mph.... 66°F with high humidity of 70%.... Yuck! The high for today is expected to be 82°F and Thunderstorms are forecast for this afternoon.
Soon, I will get back to work on the TT project. I hope to get the fiberglass siding glued down to the new plywood sheathing today before the thunderstorms hit.
Later.... 1700, my HD shift starts. Only 4 hrs today.
Enjoy this great day my friends......
Old Jun 18, 2022 | 10:16 AM
  #115
Tim Young's Avatar
Tim Young
Good morning Roy and crew!
Good luck on the TT today.
Old Jun 18, 2022 | 10:20 AM
  #116
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
It has been an interesting week with the Temperatures in the high 90's and index of 110-111° coupled with 2 sever storms dropping 1.1 inched in several hours and another dropping 0.81 in 30 minutes. On top of that we lost power for 28 hours through the sever heat. Then again 3 hours yesterday while they made permanent repairs to the down lines and broken poles. It was a large sycamore that fell, blocked the road for 4 hours and took the lines out by breaking 2 power poles off!
Well today is more seasonable in the 70's, low RH, nice breeze and warn full sun! Off to the Range for the annual picnic and social event.
Rod.... Have fun today at the picnic
I am sure glad to not be living in that humid environment !!
Lost power in that heat is sure a PITA......
Thanks for stopping by six shooting cowboy....
Old Jun 18, 2022 | 10:24 AM
  #117
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Hi Tim....
Thanks for stopping by today.....
Have some fun and say, "Hi !" to Maria.....
getting late... Time to get to work !!
Old Jun 19, 2022 | 01:09 AM
  #118
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Almost midnight.....
Stayed very busy at Home Depot tonight.... 1700 - 2100 hrs.
Home to leftover beef stew and fresh strawberries....
Made some good progress on the TT Project. Most of the fiberglass glued down.....
Getting close to finishing the fiberglass siding.....
Then the rubber seals around the slide out.
Finish inside
New tires
Compartment door won't open..... fix that
Needs a license plate bracket.
Test that everything works.......
Old Jun 19, 2022 | 06:03 AM
  #119
GLR's Avatar
GLR
Old Jun 19, 2022 | 08:36 AM
  #120
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Good morning to all the Daddies and Patriots .....
The thunderstorms missed us yesterday...... I was hoping for a bunch of rain..... Might get some during the day today. Late tonight and tomorrow is supposed to be rain.
I hope to get the rest of the fiberglass glued down and the rubber seals around the slide out installed today. Maybe the seam where the roof and siding join together.....
Weather looks to be an overcast with light winds, 54°F & 72% Humidity..... Not going to get much warmer,
After church this morning, I need to stop at HD and get more adhesive for the siding.....
Enjoy a nice Daddies Day gents.....
