Tailgate Delete Cap/Kit ???
Old May 31, 2022 | 03:33 PM
xd2200's Avatar
xd2200
2020 SD. Found this in my upper glove box while changing cabin air filter ( mouse damage.) Owners manual indicates that the three black connectors are to be used when removing the tailgate. Are the other two connectors used when installing a cap? If so how? where?
Old May 31, 2022 | 05:30 PM
mwheue's Avatar
mwheue
Not sure what your looking for... the wire for a canopy brake light can be seen in the attached thread. Not sure what the connectors in the bag plug into. https://www.ford-trucks.com/forums/1...ar-bumper.html
Old May 31, 2022 | 06:17 PM
4wd6.7L's Avatar
4wd6.7L
...and I thought 'CAP" referred to what they do. Cap off the unused connectors after tailgate removal.
Is that a typo on the label? ".......INSTRUCTION SHEET FORD PROPER USE."
Old Apr 25, 2024 | 10:17 PM
Mikecube's Avatar
Mikecube
1st Gear
I've got exact same things in my glove box. + something
Originally Posted by xd2200
Love to read more about these things. Never know I might need or use them sometime.
I'd like to know more about these things as well. Never know, might even use them at some point. Please Advise
This other item is just a tube of sort. May 1/2" diameter and 3 or 3 1/2" long. No idea what it could go to either
Old Apr 26, 2024 | 01:33 AM
KJCC's Avatar
KJCC
The lower bag is a bushing to use in your receiver to bring down a 3/4” pin hole in a 3” shank hitch to likely the 5/8 pin hole in the receiver. The plastic caps the op is referring to are used to cap the wires when you remove the tailgate.
GN1220
Jul 2, 2017 07:00 PM
Mad Mel C
WTB - Parts & other
Jan 8, 2016 09:48 PM
stevenailor
2009 - 2014 F150
Jun 22, 2009 02:02 PM
TNT in Round Rock
Jan 5, 2009 02:55 PM
