I thought I asked this question before, but cannot find it via search. Adding 4 gauges. Boost and Pyro are 2. What do you all recommend as the other 2? I am thinking
- Water Temp
-HPOP pressure
Transmission temp, I mean water temp is a good one, oil pressure.... I would want to monitor ICP more than HPOP pressure which you would need scan gauges for that, can do with android and a dongle in your OBDII port. Not necessarily a big worry though unless you're having issues.
the HPOP supplies the pressure to your injectors, which the computer reads as ICP - Injector Control Pressure or something like that. If you want to read basic oil pressure for the engine that's different, which I'm fairly certain is what the stock gauge reads. I personally wouldn't be concerned about ICP or HPOP pressure unless your truck is running like crap or you're evaluating your HPOP to run Hybrid injectors or something like that.
You can monitor oil pressure if you want, and engine temp too (coolant) - I read the other day the temp on the gauge is EOT (Engine oil temp), which if you have digital gauges that's also an option to display. Just saying HPOP isn't one I would go for, the computer already reads that and you'd be measuring 3000+psi
I’ve used a lot of glow shift and had good experience with them. Can’t beat the price. Isspro might last longer but you can probably get 3 glow shifts for the price of 1 isspro
