Led lights install
Old May 23, 2022 | 10:09 PM
Tenson's Avatar
Tenson
1st Gear
Red face Led lights install
I am trying to put Led light strip { turn , signal and Break lights } on my 89 Ford P/u . It is not working . do I need a led flasher relay for it to work ?? or load resistor ? is there a type I need ?
Old May 24, 2022 | 03:05 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome.
You may find help in the 1987 - 1996 F150 & Larger F-Series Trucks forum:
Swing by your local BC FTE chapter: https://www.ford-trucks.com/forums/forum165/
Old May 24, 2022 | 06:13 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree with Fomoko1 ^^^^^^^
The folks in the "1987 - 1996 F150 & Larger F-Series Trucks" forum can answer questions about your truck. Also, it might be a good idea to consult the manufacturer of the LED lights, they should know about this.
Old May 26, 2022 | 10:13 PM
donjamer's Avatar
donjamer
Moved to Appropriate forum
Old May 27, 2022 | 03:00 PM
Edgethis's Avatar
Edgethis
Is this the bar that runs under the tailgate? How do you have it wired?
Old Sep 23, 2024 | 02:13 PM
smoats1's Avatar
smoats1
4wd High
I am not a lighting expert, but I recently learned LED lights require the positive to be connected to the right terminal.
Old Sep 24, 2024 | 12:52 PM
MiteyF's Avatar
MiteyF
LED - light emitting DIODE. AKA, positive and negative is key. Correct.
However this thread is 2 years old.
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
Aug 9, 2019 07:36 AM
Auxbeam Lighting
Jan 17, 2017 03:20 AM
Auxbeam Lighting
Jan 15, 2017 09:20 PM
carid
Mar 7, 2016 03:25 AM
