transfer case problem
Old Nov 9, 2003 | 12:34 AM
ford190082's Avatar
ford190082
Question transfer case problem
i have a 1985 ford f150, my four wheel drive with warn lock out hubs wasn't working properly, it would shifts in four wheel high in but when i try to drive it is not ingageing, after this problem persisted i took the hubs apart and clean them and repacked with bearing grease , but still does not work after i redid the hubs i have four wheel low but still no high, when it is in four high i can hear the chain moving sounds loose does any one have any knowledge of the 208 np transfer case and if so is there a simple fix or is it a total tear down.
