96 7.3 cuts out
Old May 21, 2022 | 11:34 AM
Jared20burks's Avatar
Jared20burks
7th Gear
96 7.3 cuts out
96 7.3, starts runs and idles great, only when it's at running temp and try to take off from a stop it will just cut out like I hit the key off. It will start back up immediately and be fine and run great until I try to take off from a stop when its warmed up. I can hold it at higher rpm and then take off from a stop and it won't shut off. Filters, Injectors, and pump are all within a year old.
Old May 21, 2022 | 12:20 PM
Edgethis's Avatar
Edgethis
Is this on an auto or manual truck?
Does it do this with the AC turning on also?
Old May 21, 2022 | 12:48 PM
Jared20burks
7th Gear
It's an automatic, and the ac has never been on in it
Old May 21, 2022 | 03:20 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Nut on IPR.
Old May 23, 2022 | 03:00 PM
Jared20burks
7th Gear
Thanks, previous owner did mention new ipr, nut was there but no spacer, seems to be fixed thank you
Jeff Brillon
Nov 4, 2019 04:46 AM
96hauler
May 2, 2017 10:46 AM
dogdog130
1997 - 2003 F150
Nov 4, 2014 11:17 PM
f1501987
18
Aug 8, 2012 10:51 PM
