84 f150 transmission swap
Hi everyone, I am swapping my blown C4 for a Mazda 5 spd from a 96 f150. Both of the trucks are single cab long box 2 wd and both have the 300 4.9. Do I need to use the drive shaft I get with the manual or can I use the one that that was attached to the blown C4?
The downside to the 1996 5spd is that there will be nowhere to connect your speedometer cable. To do that you'd need a 5spd from 1988-1991, or you may be able to swap the tailshaft housing and parts from an 88-91 trans, I'm not sure.
You will also need a hydraulic manual trans pedal set from a 1984-1986 Bullnose, and a manual trans steering column (and the little blank piece for the instrument cluster if you're fussy).
1975MudRat
05-15-2012 06:41 PM
Blackandchrome1986
11-11-2010 09:49 AM
dizturbed
08-10-2010 10:32 AM
jonbrockman
Engine Swaps
06-03-2007 11:18 PM
