tailgate help
Old May 15, 2022 | 04:10 PM
Slackerme's Avatar
Slackerme
tailgate help
Had a little mishap Friday with my 22 f350 platinum
Forgot I left tailgate down and when hooked to my excised tailed and turning to sharp she pinched with the trailer
crinkled the corner over and it left a ding on the curved part
Also the hinge at bottom crinkled the shell
looking to find just the aluminum shell possibly and have it painted and all my hardware swapped over
morning wonder if I can get one painted
any help would be amazing
thanks
Dan
Old May 16, 2022 | 05:23 AM
senix's Avatar
senix
try ford parts.com and see if you can order just the shell.
I think autobody shops can do this all the time.
Old May 16, 2022 | 06:32 AM
MKGym's Avatar
MKGym
I have a tailgate shell from a 2021 King Ranch. The color is Rapid Red. Outer skin is perfect with just some scrapes & scratches on the inside surface from normal use. It has has the hole for the pop-out step (not included). I bought it last year after damaging mine with my 5th wheel. The step was jammed and I assumed there was hidden damage. Turns out I was easily able to fix mine so I didn’t use this one.
I am located on the west side of Michigan. I have a factory shipping box for it but I imagine shipping would be expensive. Let me know if you’re interested and I’ll take some pictures.
Old May 16, 2022 | 07:09 AM
Slackerme's Avatar
Slackerme
yes
of this is the same as mine?
ford logo in the corner?
Old May 16, 2022 | 07:35 AM
Flyct's Avatar
Flyct
FTE Community Team
A paintless dent repair guy would make the damage disappear. They work magic.
Tfry your dealership for a referral. They all use these guys.
EDIT: after a closer look a PDR may not fix your damage.
Old May 16, 2022 | 07:41 AM
NeverboughtanFseries's Avatar
Tailgate is prolly a $2000 part.
It's ur lucky day:
Old May 16, 2022 | 08:02 AM
MKGym's Avatar
MKGym
Originally Posted by Slackerme
yes
I will pull it out and shoot some pictures this afternoon. PMing you my phone number. Shoot me a text when you get it & I’ll text you the photos.
Old May 16, 2022 | 01:54 PM
RubenZ's Avatar
RubenZ
I would spend much to fix that. Would suck if you fix it and it happens again. Go to a dent specialist and just have them fix it.
Old May 17, 2022 | 05:28 PM
bent-1's Avatar
bent-1
I’ve seen a good number of Oxford White new take off gates for $500 or less. Bought mine from a forum member for $300, as new, even had bedliner oem sprayed on the inside panel. Also, I’d do some minor repairs on the damaged unit & use it when doing rugged work.
06pghescape
2009 - 2014 F150
Jun 9, 2021 05:28 AM
68murc
17
Apr 25, 2019 02:22 PM
Don52M3
Apr 21, 2019 02:34 PM
Matthew Barnes
Sep 6, 2016 07:57 AM
drbalazo
Apr 25, 2008 04:42 AM
