2001 Excursion 6.8L Valve Covers
Old May 9, 2022 | 10:24 PM
Luckyduck1929's Avatar
Luckyduck1929
4wd High
Hello! I've run into a problem. I was replacing the pcv grommet on my passenger side valve cover, and noticed I have a metal piece bouncing around on top of my cam shaft! From the research I've done, it looks like it's most likely a shield that prevents the pcv valve from sucking up oil.
Has anyone come across this problem? If so, do I just need a new valve cover then I'm thinking? From the little I can see through the hole the cam shaft has already worn away some metal from the shield. I've parked the truck for now and will be opening it up this week.
My main problem and question is where the heck do you find valve covers for this engine? I've gone to two different salvage yards around here and they don't have any of these engines around (only an older version that has a different valve cover). I've found they are discontinued on any kind of Ford part site. I'm at a bit of a loss.
Any help or advice would be greatly appreciated!
Old May 10, 2022 | 05:30 AM
01__Excursion's Avatar
01__Excursion
Someone on here cleaned everything up, and did a JB Weld of that piece back to the valve cover.
Old May 10, 2022 | 12:38 PM
Luckyduck1929
4wd High
Yeah I could do that. I haven't used jbweld before, I'm guessing it's not too hard for this application? Just have to really clean the surfaces off.
Old May 10, 2022 | 02:02 PM
bajaphile's Avatar
bajaphile
I've had good luck with https://car-part.com/ for salvage yard parts. Just have to pay for shipping...
tealboy1
18
Oct 9, 2025 02:58 PM
Akhnot
May 2, 2015 07:17 PM
cjben
Apr 2, 2010 10:00 PM
jlabrecquevt
1983 - 2012 Ranger & B-Series
Dec 3, 2008 08:31 PM
