Sponsored by: Real Truck
Removing Tint From Windows
Old May 9, 2022 | 09:17 AM
Colorado_Kid's Avatar
Colorado_Kid
I am moving to another state and took my truck for inspection and failed because of the tint on my windows. I could someone tell me the best way to take the tint off my windows? Thank you.
Old May 9, 2022 | 09:28 AM
Super Duty DJ's Avatar
Super Duty DJ
I have used a kit similar to this one in the past. Just be careful with the razor blade/scraper to not scratch the window. Getting a corner started with the blade and then spraying the adhesive removal spray liberally and moving slowly should allow you to remove the tint in large sheets.
O'Reilly Window Film Adhesive Remover
Old May 9, 2022 | 10:19 AM
95% stock's Avatar
95% stock
If the tint is not old a steamer will work perfect, spray it in the edge and along as you go the glue will not stay in the glass
Old May 9, 2022 | 12:32 PM
WWR's Avatar
WWR
This is exactly what I just did on an '89 K2500. Used the same product, it's got great reviews on Amazon.
However, in this case I was removing a literal meth head DIY job that never appeared to have adhered all that well anyhow....so that may have made the job easier for me
Old May 9, 2022 | 07:13 PM
speedfreak78's Avatar
speedfreak78
Use a hair drier and a razor blade. Heat the film, then peel a corner with the razor. After that just heat and peel, usually it comes right off. If it tears just use the razor to peel it again. I used to remove and reapply my tint every year for inspection. Look into getting a tint waiver if your state has that. You probably just need to get a Dr to write you a note, at least that's how it works here.
Old May 10, 2022 | 11:42 AM
Colorado_Kid
Thanks for all the advice.
I was told I could get a waiver but it would probably be a longtime before I could get an appointment.
pepperfire
Aftermarket Products
May 17, 2012 02:48 PM
ErrorS
Jul 18, 2007 07:23 PM
mizzitch
May 10, 2007 04:17 PM
kc2006
Aug 14, 2004 02:59 AM
