73 240cid automatic 3 speed
Old May 9, 2022 | 09:13 AM
73shortbed's Avatar
73shortbed
4wd Low
Will a 84 302 transmission work in my 73 with an inline 6
Old May 9, 2022 | 09:50 AM
f5fordgirl's Avatar
f5fordgirl
It will bolt to the engine ok, but the length might be different
Old May 9, 2022 | 09:55 AM
73shortbed's Avatar
73shortbed
4wd Low
What will work
Can I change tail or no
73shortbed's Avatar
73shortbed
4wd Low
What will work
Old May 9, 2022 | 10:02 AM
f5fordgirl's Avatar
f5fordgirl
Trans would have to be dismantaled and the output shaft changed also.
Old May 9, 2022 | 07:34 PM
F10B1317's Avatar
F10B1317
Might want to ask in the 73-79 forum since they switched to 1-piece driveshafts around then...but either the driveshaft will likely have to be changed or the tail or both.
Shurik
Apr 13, 2024 03:16 PM
Everlanders
Aug 13, 2018 02:30 PM
