95 f150 engine problem
Old May 8, 2022 | 10:05 AM
Mrgrass's Avatar
Mrgrass
Have a 95 Ford at 1:50 with an with an automatic transmission change transmission to a standard transmission and having stubble issues on engine it is bucking while in gear in gear hit the clutch engine is stuck it is stumbling on idol idol or throttle dies out Any thoughts thoughts I've read lots of threads on using a 94 or I've heard of using other ECM's out of other trucks but mine has the mass air flow sensor and that was other ECM's need a map sensor sensor what would be my options Thanks in advance
Old May 8, 2022 | 02:31 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome to FTE. I see you have found the 87/96 tech forum, good luck with your inquiry.
Old May 8, 2022 | 07:25 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Welcome aboard!
Old May 9, 2022 | 06:11 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Since Mrgrass resurrected a 12 year old thread to ask a question instead of asking in a new thread, would you move this to the correct forum?
brianhks
New Member Introductions
Feb 10, 2022 12:05 AM
