Sponsored by: Real Truck
Pinion
Old May 6, 2022 | 10:04 AM
Larry63's Avatar
Larry63
Pinion
I have a 2013 f250 diesel 4x4 I'm replacing rear axle pinion bearing and seal. Can you give me the torque and pre load of it
Old May 6, 2022 | 01:28 PM
WWR's Avatar
WWR
The 10.5 uses a crush sleeve so there is no ultimate torque value for the pinion nut. You want to see around 20 in lbs of rotational torque with new bearings. Can apparently be as high as 29.
Have a plan for getting that crush sleeve started, they can be a real bear to get them to collapse initially.
I personally only check this with the carrier removed, but if you're truly replacing both pinion bearings you'll have the carrier out anyhow
GiggityBurns
May 14, 2018 02:51 PM
79 bronc
Sep 18, 2010 01:54 PM
jade79
1983 - 2012 Ranger & B-Series
Nov 1, 2009 09:25 PM
XLnAK
Jan 15, 2009 08:35 PM
brokebronco
Jul 26, 2002 01:22 PM
