Sponsored by: Real Truck
AC starting point
Old May 6, 2022 | 07:40 AM
rigid1's Avatar
rigid1
AC starting point
I have an 03 that I bought last year. The Ac is not working. Blower /control module all work. I have the dye/ correct oil and the tool to inject it to find leaks. Also have pressure gauges. I plan to check pressure readings first. My guess is there is no or low pressure. My understanding is that the compressor will not try to engage at all if the pressure is not correct. Hopefully I can find the leak. Is there a way to test the compressor to confirm it should work with the proper charge?
Thank you
Old May 6, 2022 | 12:05 PM
bwguardian's Avatar
bwguardian
You're on the right track...check the pressures first and take into account the outside temperature...
Old May 6, 2022 | 08:23 PM
projectSHO89's Avatar
projectSHO89
Read the HVAC FAQS in the HVAC sub-forum. They apply to your truck although written for the F150. Link is in my signature.
A quick "cheat" is to disconnect the low pressure cycling switch and jumper the connector pins in the harness and see whether or not the clutch pulls in. If it does, the system is likely discharged (or the switch is bad). If it doesn't, see the FAQs for details.
Old May 6, 2022 | 11:20 PM
rigid1's Avatar
rigid1
Thank you for the link. There is a lot of good information in that post. I will start there.
Cbx1013
Jul 24, 2017 09:41 AM
JWI1965
May 21, 2017 10:54 PM
Twilight Lumber Co
6.4L Power Stroke Diesel
Jul 4, 2012 11:02 AM
96DRW
Sep 7, 2005 12:38 PM
Merlin509
Jun 8, 2005 06:09 AM
