Vacuum Reservoir
Old May 3, 2022 | 02:26 PM
toolman60's Avatar
toolman60
Vacuum Reservoir
Can someone confirm the part # for the vacuum reservoir for the 87 F150 4.9. The one on truck has a pin hole in it somewhere have not located it to see if it is fixable yet.
I have 1 number and 1 place shows it as coffee can not in stock and another is showing the same number as a plastic box that looks to be the charcoal canister. Another place showing it as the can in stock but does not fit the truck.
Here is the number I am searching: D5TZ-9E453-A
Old May 3, 2022 | 06:28 PM
torq'ta 5 8's Avatar
torq'ta 5 8
should be coffee/tomato can, but at this point take what you can get, now, cheap, I got the softball looking one, mines is coffee/tomato like yours.
Old May 3, 2022 | 08:26 PM
SFaulken's Avatar
SFaulken
AFAIK, the Tomato Can reservoirs are NLA, and Unobtanium. Go for one of the later softball ones.
Old May 7, 2022 | 06:10 PM
AuroraGirl's Avatar
AuroraGirl
GM plastic ball reservoirs are widely available and do the same thing, some hanged on the hood even lol.
Old May 7, 2022 | 07:42 PM
spurredon's Avatar
spurredon
But a can of tomato juice and remake your own Once painted black it will look factory. Use black RTV to hold the fitting in place.
Old May 8, 2022 | 03:41 PM
AuroraGirl's Avatar
AuroraGirl
use a urethane to permanently set a fitting in place lol
Old May 8, 2022 | 06:01 PM
torq'ta 5 8
Just remember to use fitting from old can, it has check valve in it that is needed, to keep the vacuum in the can, my check valve went bad, and vacuum couldnt even open the EGR when commanded.
Old May 8, 2022 | 06:43 PM
Scndsin's Avatar
Scndsin
01 to 12 Escape Vac tank. Same as a lot of Mustangs which NPD sells for about $125.
I paid $5, maybe 10 @ my local PAP
Has a slide/snap bracket that will bolt to inner fender in stock location if you want it to.
You'll need the check valve that's with it.
Old May 9, 2022 | 05:29 AM
toolman60's Avatar
toolman60
I found 3 trucks with fairly new coffee cans still had paint on them as they looked replaced in last couple of years. And all of them had a bad check valve in the can. Not a big deal as you can always add it external as the 1 in the Escape. All the plastic ones in the newer trucks were gone. I am going to make a trip up to the car pick an pull and find me a plastic one. I was at the truck only place this past weekend.
Old May 9, 2022 | 05:59 AM
AuroraGirl's Avatar
AuroraGirl
Does the OE plastic tank have a check valve inside ? 2 ports come off it, one says vac and the other doesnt , which one does what and where is its check valve
Old May 9, 2022 | 07:14 AM
toolman60's Avatar
toolman60
From what I have read and testing on mine. The manifold side of the coffee can has a check valve. The check valve will close at WOT or loss of vacuum from engine to keep that little puff of vacuum for the EGR,TAB an TAD solenoids.
I could be 100% wrong but that is my theory after testing and reading.
It was raining here so I left the P&P so will be heading back again.
Old May 9, 2022 | 07:20 AM
AuroraGirl's Avatar
AuroraGirl
The reason I ask is that I have been fixing some broken vac lines and also been monitoring my live data and I already know that my check valve for the HVAC is bad because i can be driving a long and it will just un-positiion the doors. I think so at least. The truck is running much ebtter overall but I cannot tell if things are "just" right. But I still have a broken canister so no proper usage of tank fumes, so I could be fighting that possibly.
Old May 9, 2022 | 07:40 AM
toolman60's Avatar
toolman60
Blend doors or defrost,vent floor switching will be because of loss of vacuum. Had that problem on my son's 99 F350.His leak was at the canister and also his auto 4WD hubs would not work. I played a couple days on that rascal on/off with the mightvac until I got all of his leaks fixed.
The charcoal canister on this 87 is still good after 34 years so I was lucky on that part not being split from old age.
Old May 9, 2022 | 09:36 AM
toolman60's Avatar
toolman60
Looking at the 1 from the Escape in picture the check valve is external in the line.
Do not quote me but I believe the 1 marked VAC is your source of vacuum from engine.
Old May 9, 2022 | 09:55 AM
Scndsin's Avatar
Scndsin
Yes, the escape tank is just a tank. Must use a check valve to store vac in canister.
