Engine Cleaning?
Old May 3, 2022 | 05:55 AM
IndyDog's Avatar
IndyDog
Engine Cleaning?
Has anybody here cleaned off their engine? I was checking the oil the other day and was looking around the engine/compartment and was wondering if I could use a gentle spray from the hose to clean it off without causing harm to some of the components. Any thoughts?
Old May 3, 2022 | 08:44 AM
scott91370's Avatar
scott91370
I've used the pressure washer on mine - be careful and don't get the nozzle right on top of the sensors/plugs.
I start it up and let it run while I spray it.
Old May 3, 2022 | 08:46 AM
KJ Smith's Avatar
KJ Smith
I clean mine on a regular basis.
Low pressure wet down.
A little simple green and brush.
Low pressure rinse.
Old May 3, 2022 | 10:36 AM
JKBrad's Avatar
JKBrad
I clean mine about once a year at the quarter car wash. I just don't get the tip of the wand really close to anything. Every once in a while I blow the dust out with an air gun and wipe the excess away. I keep it clean because I do most of the work on it. I even wipe out the drain tray after I change the oil filter.
Old May 3, 2022 | 11:46 AM
Olds64's Avatar
Olds64
I've heard of auto detailers spraying Armor All tire dressing all over engines. I've never done it though. I check the oil, ATF, coolant, etc. regularly in my 86 F250 and other classics. I don't generally lift the hood of my 2020 F150.
Old May 3, 2022 | 01:10 PM
Beechkid's Avatar
Beechkid
I recommend simple green, spray the compartment/area liberally and I use a HF engine cleaning gun that hooks to a compressor & is of course cheap....but it works well....I use a bucket of hot water to feed the gun and rinse the compartment. The gun has pinpoint like accuracy that almost eliminates any physical scrubbing and avoid saturating e-connectors/components. The most important item....do not use any solvent based engine cleaning product- the underhood e-boxes & harnesses can't take it.
The biggest concern is the connectors...... either wrap them in plastic or by hand wash/rinse... a trickle of water is ok but you definitely don't want to spray water
Old May 3, 2022 | 01:18 PM
SpencerPJ's Avatar
SpencerPJ
I use dawn soap and a soft brush and rag. Light spray off then use my leaf blower to get residual water off, followed by a damp towel.
Old May 3, 2022 | 04:47 PM
Kingofwylietx's Avatar
Kingofwylietx
I use a nozzle sprayer attached to my water hose about once a year.
I've done this my whole life with no issues.
You might not want to eat off it, but it keeps everything looking respectable.
Old May 4, 2022 | 05:50 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I haven't cleaned a car engine in about 30 years, too scared and it hasn't made a bit of difference in how it runs.
shockr4
2004 - 2008 F150
Feb 15, 2014 08:37 PM
Brutl_Force
Jul 6, 2010 09:41 AM
mongo75
25
Nov 30, 2009 03:35 PM
basstardo
General Automotive Discussion
17
Jun 30, 2004 03:46 PM
Quackhead94ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 13, 2004 03:18 PM
