I have a 92 f350 2x4 dually. I’m in the middle of doing a complete restore wit Cummins swap and Dana 60 front swap. Ive got the truck down to the frame and the front end dropped. I ordered all my parts from sky manufacturing. I got the 5 inch reverse shackle kit, dual shock brackets, adjustable panhard bar, and the 4 inch drop panhard bar bracket, and the front end box in kit that I need. One of my problems is I got my holes drilled for the box in kit and I can’t get it mounted to the frame wich I haven’t welded anything yet because the holes on my reverse shackle kit do not line up right. There’s only 3 holes that line up between the box in kit and the rsk. Like the 4th hole is completely off. It’s the one closest to the front. I can’t find anything on that and I’ve been looking for a couple of days.
so my questions are is there only suppose to be 3 bolts holding the rsk on maybe?
since I have the 2wd frame I don’t have any holes in my frame for the dual shock mounts or the drop pandhard bar bracket. Both say should just be bolt on to the original holes on the 4x4 frame but obviously I don’t have that and they don’t say anything else on installation for a 2wd truck.
