Sponsored by: Real Truck
Drive Shaft Help
Old Nov 8, 2003 | 11:06 AM
kgirouard's Avatar
kgirouard
Angry Drive Shaft Help
OK I’m changing the Rear Drive shaft Universals on My 1989 F250 XLT split shaft and I'm having a hard time getting the shaft out!! Do you have any suggestions? do you need to remove the center support? These bolts are tight and rusted ? Thanks any Ideas would be great!!
Ken
Old Nov 9, 2003 | 09:49 PM
BCS_tx_dieselman's Avatar
BCS_tx_dieselman
Its best to drop the whole shaft,so you can ck all the U jionts & center support bearing on your work bench. PS. get a friend to help so you won't bust your knuckles & a cheater pipe or impact.
