40mph and bouncy!
Old Apr 26, 2022 | 02:05 PM
tomkins's Avatar
tomkins
40mph and bouncy!
Just replaced the shocks on my 1974 F250. Not sure if it has any correlation but once I hit 40mph, the ride gets very bouncy / bumpy . Obviously I should check tire balance first, but what else should I look at / test ?
Old Apr 26, 2022 | 03:11 PM
440 sixpack's Avatar
440 sixpack
What size tires?
There isn't much to look at other than tire condition and balance. possibly a really messed up wheel but you should see it.
Old Apr 26, 2022 | 07:30 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Did it do the same thing BEFORE you replace the shocks? Is that why you replaced the shocks?
Did you get the correct shocks for your application, cheapest Amazon shocks are not always the best.
Did you throw a tire weight, did you break a cord in a tire? Any sidewall bulge?
Swap the front tires (as in the rims and tires) for the rear (rims and tires) and take it for a test drive, same road, same speed, same reaction?
Insp the tires very well, maybe you have a bad one (internally)? Insp rims for new damage.
Did you change or remove anything that was in the bed?
Old Apr 27, 2022 | 08:52 AM
tomkins's Avatar
tomkins
Tire size : 245/75/16
Old Apr 27, 2022 | 08:55 AM
tomkins's Avatar
tomkins
It did not bounce prior to shocks, or at least not like this. I replaced the shocks because of a clunking sound in the front right when going over bumps, thinking that was the issue. Plus the shocks were ancient. I purchased these shocks,
Amazon Amazon
which had great reviews across the board on a variety of sites. Hopefully they are what was needed. I do not notice any issues with tires and nothing new in the bed. I think the first step will be to take the tires in for balancing and see what the professionals find. Thanks for your help my friend !
Old Apr 27, 2022 | 09:03 AM
440 sixpack
The shocks may not be doing a good job of dampening a bounce but they will not cause a bounce. and the chances you got shocks that are all totally useless out of the box is remote.
So by bounce do you mean rough ride ? shocks will cause that. but they won't cause you to start bouncing .
Old Apr 27, 2022 | 09:27 AM
tbear853's Avatar
tbear853
That clunk in the right front ... did you find the source?
What or who lead you to think it was needing shocks?
Old Apr 27, 2022 | 09:36 AM
tomkins's Avatar
tomkins
By bounce I mean rapid bouncing. Hard to explain but when I hit exactly 40mph it starts bouncing.
Old Apr 27, 2022 | 09:38 AM
tomkins's Avatar
tomkins
I have not found the source yet. The truck had sat for many many years and the shocks were rusted and corroded. Thus, I replaced them along with all the fluids, radiator, water pump, etc etc just to get her running.
Old Apr 27, 2022 | 09:47 AM
440 sixpack
It's tires then. either bad tires or out of balance.
Old Apr 27, 2022 | 11:45 AM
tbear853's Avatar
tbear853
Agree, either a tire threw a bit of weight off, or is suffering from a tread / ply separation.
Old Apr 27, 2022 | 02:11 PM
Mark8man's Avatar
Mark8man
Ties are likely flat spotted from sitting. You can remove shocks completely on an F-250 and assuming a relatively smooth road, its not going to bounce as you are describing.
Old Apr 28, 2022 | 08:33 AM
Johnkimble's Avatar
Johnkimble
Is the shock mount to the frame solid? My front shock mount at the frame (2 bolts) were loose and causing a rough ride.
Old Apr 28, 2022 | 09:22 AM
440 sixpack
Rough ride possibly, but he says it's bouncing. bouncing requires momentum and shocks have no way to produce momentum.
zagain
Oct 7, 2020 06:02 PM
Trevor Stephens
Sep 28, 2020 08:58 PM
FordFETruck
19
Jun 17, 2012 02:11 PM
boonie
Apr 16, 2007 07:58 PM
gdsqdcr
1997 - 2003 F150
Apr 27, 2006 10:38 AM
