Toggle Turn Signals
Old Apr 24, 2022 | 06:07 PM
cfurlow165's Avatar
cfurlow165
Toggle Turn Signals
I have a 94 Ranger 3.0 with no turn signal lights; I'm assuming it's a bad, multi switch or combination switch you're right proportion still works not sure about the brights.
anyway that's really not what this is about I'm trying to remove the turn signals to a toggle switch but I can't figure out where the power is coming in
​​​​​​ I am completely new at this and any electrical knowledge is based on what I've learned from here and YouTube to the best of my knowledge power to the combination switch appears to be coming in on a purple wire with hash marks.
I can't find this wire and I'm not even sure that's right wire to attach my toggle switch.
does anyone have any suggestions or can you just tell me the right way to wire the starter switch the simplest way possible
Old Apr 25, 2022 | 03:03 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I have to ask: What is the reason for not replacing the multifunction switch and instead wiring them up to a toggle switch? What are you going to do…flip the switch on and off when you want to make a turn?
Is there something wrong with the ignition lock cylinder and the switch? It isn’t going to be street drivin so you aren’t worried about someone taking it?
51FordTN
Dec 15, 2012 05:57 AM
Glxy66
Electrical Systems/Wiring
Apr 29, 2012 08:05 AM
alex76-f250
Jan 11, 2010 11:39 PM
DT 466Man
May 6, 2006 12:59 PM
