1978 - 1996 Big Bronco
Radius Arm question
Old Nov 8, 2003 | 08:54 AM
dazman's Avatar
dazman
Radius Arm question
I was changing the bushing on my radius arms when I noticed some of the metal was eaten away under the rubber.
The part affected is the portion of the shaft where the larger bushing sits and the metal has thinned and is bent slightly. I doubt I can change it before the snow flies.
How much work is it to change one?
I've changed the ball joints so I figure the spindles have to be removed to access the lower bolt. How does the top of the radius arm come off?
