Oil sensor reading high key on engine off.
I started the engine for the first time since building it and I gotta say I was so relieved it ran. But after playing around with it I find that the oil guage is reading high when the key is on, engine off. I unplugged the sensor and nothing changed. But when I start the truck it goes down. I'm using the old sensor that was in the 429 but I still have the sensor from the 400 I could try. It worked just fine when the 400 was in it and as far as I know I didn't mess with any of that wiring. I'm quite confused.
Also seperate question.. I think my timing is pretty good. But when trying to start I get real high flames shoot out the carb sometimes. So I give it a few shots of fuel in the carb(with bottle) and then start it and no flames.. is this timing or lean fuel? Truck doesnt stay idle without a little help but to me sounds quite smooth. Personally feel it's a mixture thing. But anyways need to be sure I have oil pressure. I ran a drill on the pump during the late stages of the build and I did have good circulation so I'm not quite sure.
-Think I attached a short video of it running and dying.
Flames shooting out of the carburetor makes me immediately think the ignition timing is too far advanced. A very lean condition can also cause flames to jump out the carburetor. Usually with a lean condition, it'll just flame, but not throw fuel out and catch stuff on fire. But it's still bad juju for the pistons and valves. If it throws fuel and flames, I'd suspect a very rich condition, or valves stuck open, or the camshaft is too far advanced. There's two gauges that can be a big help here. Air / Fuel Ratio, and vacuum gauges. How the A/FR gauge helps is obvious. But the vacuum gauge can tell you a lot of things, in this case, if you've got valves stuck open, or valves open at the wrong time (camshaft timing).
-I replaced the starter wire because previous wire got cooked I guess.
-shortend negative batt and bolted directly to block. Below cylinder 1.
ELectric choke I grounded to the metal coil bracket.
and positive to a switch that used to run an electric rad fan.
That's all the wiring I had done.
As for the flame. It only happens sometimes and only at start up if I have to crank it a few times. When I set the timing I double check it and set it to 12° advance from zero. First time by hand without starter hooked up. And second time with starter hooked up to assure I was on compression stroke still read 12° at that time also.
And you guys are gonna laugh but I forgot to hook up the PCV line and that's why she wouldn't idle.
It's %100 now attached a video of it start and run.
Just gotta burp the rad a bit and burn the paint off the headers cuz they smoke a bit
