88 F150 with idle problems
Old Nov 8, 2003 | 12:32 AM
bourbon's Avatar
bourbon
suprise suprise
i just read another post that said the tube from the EGR valve to the exhaust manifold should not be a two piece tube.
well, mine is in two pieces at the ribbed portion of the tube. i assumed it was made this way since it looked cut off and not broke in two. also, i think one fit into the other a little ways?
should this tube be in two pieces???????????????????
i rebuilt this engine because it had an idle problem AND IT STILL HAS THE IDLE PROBLEM!!!!!!!!!
HELP HELP HEEEEEEEEEEEEEEEEEEEEEEEEEEEELP
ps what is the ribbed portion (in the middle of the tube) for? seemed to me one part of the ribbed part turned into the other a little ways?????
thanks for any help
Old Nov 8, 2003 | 12:36 AM
bourbon's Avatar
bourbon
oops i forgot, it has the 351 in it
Old Nov 8, 2003 | 07:51 PM
bourbon's Avatar
bourbon
ttt does anyone know???
Old Nov 8, 2003 | 11:58 PM
steve83's Avatar
steve83
No, it should be one continuous, sealed pipe. The ribbed section is to allow for flex from thermal expansion and vibration. You're leaking exhaust into the engine compartment, and it may be blowing onto plastic parts that can't take the heat. Replace it.
The idle problem is separate.
Old Nov 9, 2003 | 12:45 AM
bourbon's Avatar
bourbon
thanks for the reply steve! it could have something to do with my idle problem.
