Hi All,
I'm new to this forum.
I have a 2019 f-150 with 8,000 miles. I'm past the manufacturers warranty. Recently the readouts on the dash board have Mal functioned. I now have no digital read outs for fuel, trip, engine oil temp, trans temp etc, The ignition key chime starts when I approach the vehicle even though there is no key is in the ignition. HELP!
Welcome to FTE. The site is broken into various forums that are further broken into sub forums. These sub forums are your guide(s) to good, solid information and assistance. For your truck, you need to take your issues to the Newer Light Duty Trucks section then the, 2015 to 2020 sub section.
Check the main ground cable on the battery first, then the battery itself. Weird things start to happen when the battery isn't in a perfect state of charge. Being 3 years old, if you have the original battery it's on borrowed time.
Hi All,
Cran Fan
Based on the mileage you posted, the only warranty that has expired, and that depends on the month and day it was purchased, is the actual 3 year part of the which ever comes first 3/36K bumper to bumper warranty.
