E350 Rear Headliner Leaking
Old May 3, 2022 | 05:00 AM
JWA's Avatar
JWA
Glad you found and corrected the leaking for now---its bound to return at some point if the original butyl tape was left in place.
The butyl doesn't wear out per se it simply becomes compressed and shrinks from age which allows water to leak past it. This then causes the nuts to feel loose, tightening them compresses the remaining butyl to re-seal against the body.
The fact your van is an E-350 has no bearing on the butyl----there is no difference in the bodies of any E-Series van regardless its GVW rating, this is just one of those things that happens over time..
Old May 3, 2022 | 11:51 AM
Mike1's Avatar
Mike1
So being that the tape compresses it probably wouldn't have any benefit to put thread locker on the window studs would it?
Old May 4, 2022 | 03:31 AM
JWA's Avatar
JWA
No but it would help make removing the windows exceptionally difficult should someone choose to do this job correctly.
BigRedE350NJ
34
Jun 27, 2023 08:53 PM
Kapusta
Apr 14, 2023 08:00 AM
Wheeler.M1
Jan 13, 2022 12:07 PM
Paulford8
2009 - 2014 F150
36
Jan 3, 2012 04:41 PM
entomber
1978 - 1996 Big Bronco
Jul 18, 2004 05:04 PM
