Does TPMS Reset also Clear Trailer TPMS if equipped?
Old Apr 13, 2022 | 12:14 PM
nickshu's Avatar
nickshu
Recent tire rotation on my 2021. Dealer did not reset TPMS so now the truck thinks the front wheels are the rear and vice/versa as far as the dash tire pressure display. I read the factory reset procedure in the owner's manual (now wonder the dealer doesn't do it, it's a PITA).
I have the factory Trailer backup camera and TPMS that I use w/ my trailer.
If I reset the TPMS on the truck will it delete the trailer TPMS sensors such that I also have to go hookup my trailer and do the reset procedure on the trailer too so it will read tire pressures again?
This is a huge PITA too bad Ford doesn't have an easy procedure w/ an OBD2 scanner to just swap the front/rear sensors...or do they??
Thanks in advance guys.
Old Apr 13, 2022 | 12:27 PM
smikesF350's Avatar
smikesF350
On my 2020, the dealer told me the system will reset on it's own are driving a few miles. I have had the tires rotated several times now and so far that seem to be the case. After the first couple of rotations I stopped looking before leaving the service center. The Service writer said the system some how detects the tires location, but he could not explain how. My guess is that it has something to do with signal strength, but that's just a guess.
Old Apr 13, 2022 | 12:31 PM
nickshu's Avatar
nickshu
Good to know....it's been 3 days and it's still backwards. I'll give it another week no rush for me until I am towing again the week after. Thank you.
Old Apr 13, 2022 | 12:45 PM
powerboatr's Avatar
powerboatr
mine reset within a few miles after last rotation
i keep fronts at 65 and rear at 60 empty
dash indicated correct PSI within a few miles.
Old Apr 13, 2022 | 12:54 PM
smikesF350's Avatar
smikesF350
Yes, Mine reset within a few miles also. If your has been days and you have put miles on, then there may be a issue.
Old Apr 13, 2022 | 05:54 PM
rklavoon's Avatar
rklavoon
After a recent oil change amd tite rotation at the dealer my sensors did not reset to the correct location. I had to do them myself. In doing so, it did not reset the TPMS sesnors I have in my travel trailer.
Old Apr 13, 2022 | 11:28 PM
HRTKD's Avatar
HRTKD
Any tire shop should be able to reset the truck's TPMS sensors. The procedure they use is not the procedure that the average owner has to go through. I have a TPMS tool and it takes me about two minutes to reset the TPMS on my other cars. I haven't had to use it on my F-350 because, like the other posts in the thread, mine resets on its own after a couple miles of driving.
Old Apr 14, 2022 | 06:35 AM
B-ManFX4's Avatar
B-ManFX4
Mine resets automatically as well. However, if you want to do it without letting air out of the tire this is a cheap tool that works:
https://smile.amazon.com/JDiag-Relea...ef_=ast_sto_dp
Old Apr 17, 2022 | 07:15 AM
nickshu's Avatar
nickshu
Reporting back... My TPMS did reset itself finally. It too 6 days of driving since the tire rotation for it to do so. All good now.
shanew
Aug 18, 2021 10:09 AM
SUPERDUTY_08
Jul 20, 2020 10:56 PM
CrossCut
2009 - 2014 F150
Feb 14, 2019 07:53 PM
Olbie
Sep 5, 2018 03:59 PM
CASAJOE
6.7L Power Stroke Diesel
Apr 2, 2017 11:53 AM
