Sponsored by: Auxito
Brake/Turn Light Electrical Issue
Old Apr 12, 2022 | 07:15 PM
DirtGreen's Avatar
DirtGreen
A few days ago, I noticed my driver's side brake light/turn indicator has gone out and I cannot figure out where the issue is coming from.
The bulb's good, fuses are good, the pins are all connected to the multifunction switch on the steering column, and the test light is illuminating at the socket.
What else am I missing?
Today I realized while testing the hazards, the center-cab light won't work either. I don't know if that's related, but I know it was working when I first saw the turn light was out.
The front turn light flashes fast and the indicator on the dash is illuminating.
Any help is appreciated. Obviously I need these working to be road legal so I'm on borrowed time.
edit: the above-cab bulb is also good although I didn't get a chance to test it with the light or a multimeter before it started raining
Old Apr 12, 2022 | 07:37 PM
projectSHO89's Avatar
projectSHO89
It's not supposed to to come on when the hazards are activated (only), it's supposed to only come on when the brake pedal is pressed.
Uh, what, exactly, were you testing?
Doe that parking lamp bulb work or not? If not, check the socket ground circuit since it is shared with the stop/turn filament.
Old Apr 12, 2022 | 08:07 PM
DirtGreen's Avatar
DirtGreen
Well that's embarrassing. I couldn't sworn I saw it flashing fast when I had the hazards on.
My friend was the one with the test light in his hand but he established there was power going to socket.
The parking lamp bulbs on both sides are working.
Old Apr 12, 2022 | 10:33 PM
Airborne 82nd's Avatar
Airborne 82nd
What year and model is this?
OK Dirt I'm a little slow so I need to ask
You said the center-cab light won't work either
Where is this center-cab light? I have a thought that it is called something else.
Then this
OK it is illuminating. Is it steady or flashing ? Fast ?slow ?
Then this
What cab bulb? If you could not test it how do you know it is good?
Do you know that behind the bumper there is a connector that goes from one side to the other on the tail lights? Power comes from up front goes to one side and the connector feeds the other side.
Old Apr 13, 2022 | 04:47 AM
manicmechanic007's Avatar
manicmechanic007
Cyclops or center brake lamp
Sure sounds like ghost in the machine type stuff
Usually resolved by a new TS switch unless you have an old one and it's wired wrong
Yes a year in the OP is what you need
jackmaddux
Aug 5, 2020 07:57 PM
69monster
Apr 22, 2010 12:51 PM
Hometown Pride
Apr 1, 2010 08:49 PM
ItchSappinR1
Electrical Systems/Wiring
Jan 10, 2006 09:08 PM
joel1973
1983 - 2012 Ranger & B-Series
Jun 20, 2004 10:46 AM
