Glow plug relay
Old Nov 7, 2003 | 06:58 PM
Bolliger's Avatar
Bolliger
Glow plug relay
Can anyone tell me exactly where the glow plug relay is when
facing the engine from the front? 99 7.3
Thanks,
B
Old Nov 7, 2003 | 08:05 PM
theologian's Avatar
theologian
I should know, but can't remember. If nobody has posted the reply by tomorrow morning, I will look at the '02 and let you know. I am not prepared to go look tonight, because it is raining hard, and I shrink in the wet...
Theo
Old Nov 7, 2003 | 09:25 PM
Bolliger's Avatar
Bolliger
Thanks,
B
Old Nov 8, 2003 | 12:07 AM
greg_23805's Avatar
greg_23805
This is somewhat of a guess on exact location but it is behind the fuel filter. Look for a round component about 1 1/2 inches in diameter with heavy gauge, say #10 wires connected to it. All of mine have had a plastic cover on them which slips over top the two bolts that the wires connect to.
If you suspect a problem with it, use an ohmmeter and :
remove the wires and measure the resistance, with key off. If you get any resistance at all, the contacts are slightly shorted out. This is not uncommon and will lead to premature glow plug failure since you are apply some voltage to the glow plugs all the time.
Then have your digital volt meter ready while someone turns the key on, in voltage mode, dc, put your two probes, one on each of the bolts where the wires are connected. If you get any voltage reading, there is a voltage drop across the contacts. The higher the voltage, the worse the drop. The drop is caused by the contacts burning and the conductive surface is not even.
If you find either of these reading above to be true, replace the relay.
Old Nov 8, 2003 | 02:46 PM
FORD DIESEL's Avatar
FORD DIESEL
Talking
has any body replace their glow plug relay lately,,,how much does it cost for one,,eher is a good place to buy one at.beside the ford dealership.
Old Nov 8, 2003 | 03:44 PM
patuca's Avatar
patuca
i haven't replaced mine, but i priced one....at the dealer here in town they quoted me 96 bucks....an aftermarket dealer in truck parts gave me a price of 87 bucks.... and i believe napa had some for even cheaper than that.
Old Nov 9, 2003 | 09:06 AM
Born with a hammer's Avatar
Born with a hammer
I got mine from my local International dealer. it was far cheaper than the above mentioned prices. Dont recall $ exactly. it's a chinch to replace. Just remove the fancy fuel filter cover and there it is.
Old Nov 9, 2003 | 11:47 AM
mikewalsh1's Avatar
mikewalsh1
I bought one last summer for about 60 bucks at the International dealer it is on yop of the engine behind the fuel filter.
Old Nov 9, 2003 | 02:46 PM
Bolliger's Avatar
Bolliger
Thanks to all for your help!
B
Old Nov 9, 2003 | 03:02 PM
Skeetshooter's Avatar
Skeetshooter
Does anyone still have the IH part number for the relay?? I may need one for a 99.5 model year PSD.
