Ground issue?
Old Apr 5, 2022 | 03:38 PM
powerstroke739's Avatar
powerstroke739
Ground issue?
So long story short I am swapping a 7.3 idi to a powerstroke. New motor and tranny are in. All cab and engine bay harnesses swapped. I turned key on and idm relay clicked for a few seconds then glow plugs cycled and after cranking for a little bit it fired up and runs good. If I press the brake pedal the truck instantly dies. If I unplug the switch on brake pedal it runs fine when brakes are pressed. I have no communication to pcm with scan tool. I thought it might be a ground issue but I have double checked and I have all grounds on that I know of. Any help would be appreciated
Old Apr 6, 2022 | 04:04 PM
timrothschild1's Avatar
timrothschild1
I know this will sound funny, but make sure all your bulbs are working, including the third light top rear of cab. I also had issues once when i disconnected my radio harness and used just a hot and a ground. Did not have proper grounding until I jumped a wire on that factory connecter on back of radio. Good luck
Elanham59
23
Sep 23, 2021 08:14 PM
DieselKing69
May 23, 2021 10:50 AM
merc123
22
Aug 26, 2019 08:46 AM
LucyRydermusic
May 26, 2013 01:01 PM
96stroker84
Nov 16, 2010 12:57 PM
