Sponsored by: Real Truck
F550
Old Apr 3, 2022 | 10:15 AM
superdutyfan's Avatar
superdutyfan
F550
We have a 2003 f550 6.0L 4x4 reg cab. I want to connect my small slip tank directly to the fuel lines and eliminate the factory fuel tank. The slip tank will sit on the flat deck behind the cab. What will be the best way to do this and will I gravity feed or will I need a fuel pump? I will not be using the factory tank due to already replaced it 3 times due to holes developing in it so tiing into the over flow in the fill neck is not an option. I want to connect directly to the fuel system. I waz thinking maybe tie into where the fuel filter is underneath on the frame rail. Thanks​​​​​​​
Old Apr 5, 2022 | 12:16 AM
GGALLIN1776's Avatar
GGALLIN1776
Won't work without a pump, you're looking at atleast $1k not inc new lines & all that. The cheapest bed tank I saw today while looking to do some fuel system repairs was only 40 gallons & cost $1050 with nothing included prior to taxes/shipping. The ones that had a toolbox/transfer tank started at twice that.
eoddewey
May 2, 2021 08:45 PM
Hkats
Dec 29, 2019 08:34 PM
dieselfueladdict
6.7L Power Stroke Diesel
Sep 2, 2018 12:27 PM
BillBraskey
Jun 9, 2017 05:27 PM
tomatu
Apr 20, 2012 07:22 PM
