Drilling holes!!
Old Apr 1, 2022 | 04:32 PM
eberlestock's Avatar
eberlestock
Drilling holes!!
What are you guys doing to prevent corrosion on your rigs after drilling holes? I am adding trigger long john mud flaps and will have to drill some holes in the fender wells. My plan is to drill the holes, seal up the exposed metal with por 15 paint and then use aluminum hardware with a coating of aluminum corrosion inhibitor on it. I hate to do it but I need the flaps. I already drilled into the bed to add a trailer plug and I cried a little doing that.
Old Apr 1, 2022 | 04:39 PM
srkr's Avatar
srkr
April fools!
Old Apr 1, 2022 | 06:58 PM
F250 Bushman's Avatar
F250 Bushman
Its best to not mix metals when trying to avoid corrosion. Now that you have aluminum fasteners you'll probably want to add zinc anodes like boat motors and RV hot water tanks have.
Old Apr 1, 2022 | 07:30 PM
Squanto's Avatar
Squanto
https://www.bestmaterials.com/detail...xoCewEQAvD_BwE
Old Apr 1, 2022 | 09:02 PM
honda250xtitan's Avatar
honda250xtitan
i added heat shrink to isolate the metal bolts from the aluminum to avoid whatever chemical reaction happens when you mix steel and aluminum.
Old Apr 1, 2022 | 09:58 PM
Ding126's Avatar
Ding126
I used these screws all day long, They are carbon base steel. Dont use them unless steel to steel.
When screwing to aluminum, use stainless steel fasteners
Keepin It Real
Paint & Bodywork
Mar 29, 2007 10:10 AM
nomadic
Paint & Bodywork
Feb 21, 2004 05:33 PM
bigredneck61088
Aftermarket Products
Jan 29, 2004 04:19 PM
q_ball
Paint & Bodywork
Jan 26, 2001 07:54 AM
