460 replacing a Powerstroke
Old Mar 30, 2022 | 02:36 PM
Purebeef's Avatar
Purebeef
Exploring the idea. Have a 1996 F250 Powerstroke, SB, 4WD with a E4OD and Borg Warner 4407 transfer case. I have the opportunity to buy a 460 with a C6. I want to keep 4WD. Two ideas:
1. Install the 460 with the E4OD. What would I need to do this?
2. Use the C6 with the 460. However, I’m concerned with it having to adapt to the Borg Warner 4407 transfer case. What do I have to do to the C6 to make this happen?
I would prefer to use the C6 as I want to put in a manual valve body and floor shifter.
Thanks for your help.
Old Mar 31, 2022 | 08:21 AM
Conanski's Avatar
Conanski
The diesel E4OD won't bolt to a 460.. different bolt pattern, so you don't have that option. And you should have a 4wd version of whatever trans you do use to directly mount a t-case, a 2wd version has to be completely dismantled to replace the output shaft. The 460 is well known as a pig on gas so finding a compatible E4OD would be the best option.
Old Mar 31, 2022 | 03:30 PM
85e150's Avatar
85e150
Aren't you subject to smog inspection?
dabeef
Apr 20, 2016 04:47 PM
lisagoud
Sep 19, 2011 03:49 PM
Ford4X4ingboy
Jul 22, 2011 05:28 PM
sdmayhew
N. California Chapter
Jun 29, 2008 06:00 PM
sethro
Dec 4, 2002 09:11 PM
