Sponsored by: Kumho
Sinking brake Pedal
Old Mar 26, 2022 | 10:34 AM
Emptys20!'s Avatar
Emptys20!
5th Gear
Sinking brake Pedal
Need help BAD on a 95 F350 7.3 Okay so here’s a little history of what has been done . Almost everything !! Master Cylinder , Booster , New Lines , Calipers , Been bleed numerous times . We heard at one point a larger bore master cylinder fixed this problem in a range of years So now have another new Master Cylinder with a 1 1/4 inch bore . A little better pedal but still drifts down . Rear brakes have been capped off problem appears to be in the front . Still sinking . Also only sinks when engine is running . Oh new Vacuum pump also . Any ideas ??? Need expert additive Please .
Old Mar 29, 2022 | 12:03 PM
Beechkid's Avatar
Beechkid
Bad master cylinder......................
Old Apr 2, 2022 | 04:33 PM
Bak20041's Avatar
Bak20041
I know this thread is old, but I recently had the same problem on my 2003 f250, the brake pedal would sink, turned out a banjo bolt on the rear caliper was leaking, but you basically ruled out the rear calipers, I would start by looking for leaks if you haven’t already
dan2525
Mar 25, 2018 10:52 PM
rbrungard2012
30
Jan 6, 2015 06:49 PM
wattspd
Mar 24, 2013 07:03 PM
mntneer
1997 - 2003 F150
Oct 26, 2012 01:52 PM
l'il ol diesel
Aug 8, 2007 12:01 PM
