My new F350 is lower in the rear on the drivers side. I measured it after my wife mentioned it and it is an inch lower. I measured along the sides and in the front. The front drivers side is about 1/4” lower and then rapidly gets lower as you move towards the rear. So it seems like the suspension is weak on the left rear or some adjustment is wrong if it is adjustable. Anyone else have this problem on their SD? It is a diesel platinum with 20” wheels. No lift kit. I’ll see if my local dealer can do anything.
I have never had a truck that was level side to side. Mine that I brought home last week was 1/4” different up front and 1/2” different on the rears. My last GMC was pretty similar, with a full tank slightly more.
